castellum Posted September 8, 2006 Share Posted September 8, 2006 Earlier this week I download 2.72 of Paint.net. I keep getting an error popup with the content below. Can You help me? :?: System unauthorizedAccesExeption: Acces to the registrykey 'Hey_Local_Machine\software\paint.net'is denied. at Microsoft.win32.registrykey.win32error(int32 error code, string str) ..... ..... ..... Thanks Menno Quote Link to comment Share on other sites More sharing options...
LimeLight Posted September 8, 2006 Share Posted September 8, 2006 I had an installation problem as well. Except mine included a fatal error, and a whipe of all of my Paint.NET files. Any help? Please. Quote Link to comment Share on other sites More sharing options...
LimeLight Posted September 10, 2006 Share Posted September 10, 2006 This is what the problem seems to be. I'm not a techy guy though, so if someone who knows what that means could help me, it would be awesome. PaintDotNet.Resources Assembly Version: 2.72.2432.31552 Win32 Version: 2.72.2432.31552 CodeBase: file:///C:/DOCUME~1/PREFER~1/LOCALS~1/Temp/PdnSetup/PaintDotNet.Resources.DLL ---------------------------------------- PaintDotNet.SystemLayer Assembly Version: 2.72.2432.31553 Win32 Version: 2.72.2432.31553 CodeBase: file:///C:/DOCUME~1/PREFER~1/LOCALS~1/Temp/PdnSetup/PaintDotNet.SystemLayer.DLL ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. Quote Link to comment Share on other sites More sharing options...
LimeLight Posted September 12, 2006 Share Posted September 12, 2006 Please can someone help me? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 12, 2006 Share Posted September 12, 2006 You only pasted the second half of the error log, which is completely useless ... it's just listing DLL's. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
LimeLight Posted September 13, 2006 Share Posted September 13, 2006 You only pasted the second half of the error log, which is completely useless ... it's just listing DLL's. That's all it gave me. I don't know why it would only give me the second half, but I can try it again. Quote Link to comment Share on other sites More sharing options...
LimeLight Posted September 13, 2006 Share Posted September 13, 2006 Nevermind. I needed to delete the old version entirely and then re-install the program with the framework. That fixed it. Thanks for the help though Rick. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 13, 2006 Share Posted September 13, 2006 Hmm weird, yeah. Well, it works now at least! Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
castellum Posted September 26, 2006 Author Share Posted September 26, 2006 Hi There, I posted this question some time ago. I'm glad that Lime's problem is solved. Mine is not. I havent been able to install the software until now. Can any body help?? My initial question!! Earlier this week I download 2.72 of Paint.net. I keep getting an error popup with the content below. Can You help me? System unauthorizedAccesExeption: Acces to the registrykey 'Hey_Local_Machine\software\paint.net'is denied. at Microsoft.win32.registrykey.win32error(int32 error code, string str) ..... ..... ..... Thanks Menno Quote Link to comment Share on other sites More sharing options...
Tressflin Posted October 10, 2006 Share Posted October 10, 2006 Hm... So I'm not the only one. I got the exact same error message as castellum. I've installed, uninstalled, and re-installed the .NET framework with no success. And I don't really know my way around regedit, but the permissions seem to be set to everyone. I also noticed that after the error, PdN said there was a fatal error and includes (1603). Funny thing is, the app is practically installed. I tried opening PdN when the error message came up, and it actually opened! But when I clicked ok, the green install bar went backward (uninstalling it?), and I couldn't open it anymore. Quote Link to comment Share on other sites More sharing options...
barkbark00 Posted October 10, 2006 Share Posted October 10, 2006 Do you guys have admin rights on these computers? Sounds like a rights issue... Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
Tressflin Posted October 10, 2006 Share Posted October 10, 2006 Admin rights should be set to everyone, but even when I tried it on my mom's (owner's) account, it wouldn't work. Any other ideas? Quote Link to comment Share on other sites More sharing options...
barkbark00 Posted October 10, 2006 Share Posted October 10, 2006 Get a Mac??? j/k Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
Tressflin Posted October 10, 2006 Share Posted October 10, 2006 Nope, WinXP (with SP and all that). So... Any ideas? I've been looking over some of the tutorials and plug-ins and I would love to play with them before fall break is over. :wink: Quote Link to comment Share on other sites More sharing options...
Tressflin Posted October 13, 2006 Share Posted October 13, 2006 :oops: :oops: :oops: :oops: And so that's what I get for being lazy. Barkbark00 confirmed that the problem was admin rights. I still don't understand why the issue came up, but it is now fixed. (I figured it out by installing it on the other computer and checking its settings.) For castellum, if he ever comes back: 1) Go Start -> Run -> regedit 2) Go to HKEY_LOCAL_MACHINE\SOFTWARE 3) Right-click and select permissions 4) Add your user (even if the permissions is set to "everyone") (this is where I went wrong) It should now install without error. Have fun with paint.NET! Quote Link to comment Share on other sites More sharing options...
