Puppa Posted December 9, 2009 Share Posted December 9, 2009 I've been using paint.net for about 3 months now and I only have one question about it. If I have a background like some color or anything. If I add a image I got of or some place else onto it, I have the white around the picture. Is there anyway I can get the white away so the background of the picture I took off google or somewhere shows through. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted December 9, 2009 Share Posted December 9, 2009 Hi Puppa, Welcome to the forum. First of all, please read the [rule=top]Rules[/rule]. I have edited your post title as "Help" is exactly the sort of thing that rule #6 is trying to avoid. To your inquiry: There are several methods you could try: 1. Select the white area with the magic wand and press the delete key. 2. Use SEARCH (http://www.getpaint.net/search.html) and the search string "Alphaspace". This will lead to a plugin that does exactly what you want. You'll have to download and install it though - use search again with the term "Install plugins" to find out how :wink: Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
johntoh Posted December 12, 2009 Share Posted December 12, 2009 Thanks a lot for your reply, as I was also looking for same.. Quote [url=http://www.male-enhancer.net]Best male enhancement reviews[/url] Link to comment Share on other sites More sharing options...
