rayzor51 Posted October 5, 2009 Share Posted October 5, 2009 I have a drawing with one known measurement and I have adjusted the zoom to replicate that measurement on the screen, but when I print this drawing the measurement and all other ones are always out by approx 10mm. Any ideas would be helpful and appreciated Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 6, 2009 Share Posted October 6, 2009 Try playing with the resolution (dpi): find out more..., A higher dpi will compress the pixels (more pixels per inch), making the image appear smaller when printed. A lower resolution has fewer pixels per inch, thus the image will appear larger. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
rayzor51 Posted October 6, 2009 Author Share Posted October 6, 2009 Try playing with the resolution (dpi): find out more...,A higher dpi will compress the pixels (more pixels per inch), making the image appear smaller when printed. A lower resolution has fewer pixels per inch, thus the image will appear larger. thanks Ego Eram Reputo I will check it out Quote Link to comment Share on other sites More sharing options...
