Aeliano Posted Wednesday at 12:27 AM Share Posted Wednesday at 12:27 AM Hello PDN Forum, recently I was working on a design and when I exported said design with a transparent background, the overlay had applied to the transparent background. How might I fix this? Here is what I see, and what the export is. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted Wednesday at 04:37 AM Share Posted Wednesday at 04:37 AM Hello and welcome @Aeliano Did you flatten the image prior to export? What file format did you save the exported image as? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Aeliano Posted Wednesday at 10:00 PM Author Share Posted Wednesday at 10:00 PM Hi, @Ego Eram Reputo. I always export in PDN and PNG. I use the PNG as a finished result, because the platform I use my designs on only accepts PNGs. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted Wednesday at 10:04 PM Share Posted Wednesday at 10:04 PM How about uploading the PDN image so we can have a look? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Aeliano Posted Wednesday at 10:48 PM Author Share Posted Wednesday at 10:48 PM @Ego Eram ReputoIt says PDN isnt supported. Quote Link to comment Share on other sites More sharing options...
Solution Ego Eram Reputo Posted Thursday at 12:06 AM Solution Share Posted Thursday at 12:06 AM Try zipping it then uploading. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Aeliano Posted yesterday at 12:50 AM Author Share Posted yesterday at 12:50 AM @Ego Eram ReputoNevermind, I figured out my problem, thanks for the help, though! Quote Link to comment Share on other sites More sharing options...
Tactilis Posted 19 hours ago Share Posted 19 hours ago 6 hours ago, Aeliano said: Nevermind, I figured out my problem @Aeliano It would be helpful if you could say what the problem was/how you solved it/what you learned. That way, other people searching the forum for solutions to their overlay/transparency problems won't end up reading a thread that just ends with "Nevermind..." Thanks Quote Link to comment Share on other sites More sharing options...
