MisterEDSpencer Posted June 10 Share Posted June 10 (edited) Heyyy!!! Now I know there is little that can be done about this, but I need help recovering a corrupted file of a map for an alternate timeline that I've been working on. I spent so long making it and now it's gone What can I do? Edited June 10 by null54 Made the title more descriptive Quote Link to comment Share on other sites More sharing options...
MisterEDSpencer Posted June 10 Author Share Posted June 10 (edited) Here is the file in question; it is put up on google drive: https://drive.google.com/file/d/1wcRSIDijOVuWqZqpsq9-a8Eh80mLcDx1/view?usp=sharing fixed so that you can access it. Edited June 10 by MisterEDSpencer Quote Link to comment Share on other sites More sharing options...
null54 Posted June 10 Share Posted June 10 1 hour ago, MisterEDSpencer said: Here is the file in question; it is put up on google drive The permissions on that file don't allow others to access it. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
MisterEDSpencer Posted June 10 Author Share Posted June 10 (edited) 1 hour ago, null54 said: The permissions on that file don't allow others to access it. fixed, click the link again and you should get in Edited June 10 by MisterEDSpencer Quote Link to comment Share on other sites More sharing options...
Tactilis Posted June 10 Share Posted June 10 Diagnostics when attempting to open the .pdn Exception: System.Runtime.Serialization.SerializationException: Exception thrown by worker thread ---> System.AggregateException: One or more errors occurred. (The archive entry was compressed using an unsupported compression method.) ---> System.IO.InvalidDataException: The archive entry was compressed using an unsupported compression method. at System.IO.Compression.Inflater.Inflate(FlushCode flushCode) at System.IO.Compression.Inflater.ReadInflateOutput(Byte* bufPtr, Int32 length, FlushCode flushCode, Int32& bytesRead) at System.IO.Compression.Inflater.ReadOutput(Byte* bufPtr, Int32 length, Int32& bytesRead) at System.IO.Compression.Inflater.InflateVerified(Byte* bufPtr, Int32 length) at System.IO.Compression.DeflateStream.ReadCore(Span`1 buffer) at System.IO.Stream.ReadAtLeastCore(Span`1 buffer, Int32 minimumBytes, Boolean throwOnEndOfStream) at PaintDotNet.IO.StreamExtensions.ReadAtLeast(Stream stream, ExtentPtr`1 buffer, IntPtr minimumBytes, Boolean throwOnEndOfStream) in D:\src\pdn\src\Fundamentals\IO\StreamExtensions.cs:line 66 at PaintDotNet.MemoryBlock.DecompressChunk(Byte[] compressedBytes, Int32 compressedBytesOffset, Int32 compressedBytesLength, Int32 chunkSize, Int64 chunkOffset, DeferredFormatter deferredFormatter) in D:\src\pdn\src\Core\MemoryBlock.cs:line 618 at PaintDotNet.MemoryBlock.DecompressChunk(ArrayPoolBuffer`1 compressedBytes, Int32 chunkSize, Int64 chunkOffset, DeferredFormatter deferredFormatter) in D:\src\pdn\src\Core\MemoryBlock.cs:line 597 at PaintDotNet.MemoryBlock.<>c__DisplayClass51_1.<PaintDotNet.Serialization.IDeferredSerializable.FinishDeserialization>b__0() in D:\src\pdn\src\Core\MemoryBlock.cs:line 735 at System.Threading.ExecutionContext.RunFromThreadPoolDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state) --- End of stack trace from previous location --- at System.Threading.ExecutionContext.RunFromThreadPoolDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.Tasks.Task.ExecuteWithThreadLocal(Task& currentTaskSlot, Thread threadPoolThread) --- End of inner exception stack trace --- at System.Threading.Tasks.Task.WaitAllCore(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) at PaintDotNet.MemoryBlock.PaintDotNet.Serialization.IDeferredSerializable.FinishDeserialization(Stream input, DeferredFormatter formatter) in D:\src\pdn\src\Core\MemoryBlock.cs:line 750 --- End of inner exception stack trace --- at PaintDotNet.MemoryBlock.PaintDotNet.Serialization.IDeferredSerializable.FinishDeserialization(Stream input, DeferredFormatter formatter) in D:\src\pdn\src\Core\MemoryBlock.cs:line 754 at PaintDotNet.Serialization.DeferredFormatter.FinishDeserialization(Stream input) in D:\src\pdn\src\Fundamentals\Serialization\DeferredFormatter.cs:line 132 at PaintDotNet.Document.FromStreamImpl(Stream stream) in D:\src\pdn\src\Data\Document.cs:line 1559 at PaintDotNet.Document.FromStream(Stream stream) in D:\src\pdn\src\Data\Document.cs:line 1417 at PaintDotNet.FileType.Load(Stream input) in D:\src\pdn\src\Data\FileType.cs:line 494 at PaintDotNet.Functional.Func.Eval[T1,TRet](Func`2 f, T1 arg1) in D:\src\pdn\src\Fundamentals\Functional\Func.cs:line 58 Quote Link to comment Share on other sites More sharing options...
null54 Posted June 10 Share Posted June 10 3 hours ago, MisterEDSpencer said: fixed, click the link again and you should get in I was able to load the file after launching Paint.NET with the /ignoreCorruptPDNChunks command-line parameter. Here is the re-saved file: https://www.dropbox.com/scl/fi/vynup28m52ekle06imqcm/ToDWorldMapPolitical2.pdn?rlkey=xtwfhkp4jn5mekk2wwksao9sr&e=1&st=9tznt5gs&dl=1 1 2 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
MisterEDSpencer Posted June 10 Author Share Posted June 10 1 hour ago, null54 said: I was able to load the file after launching Paint.NET with the /ignoreCorruptPDNChunks command-line parameter. Here is the re-saved file: https://www.dropbox.com/scl/fi/vynup28m52ekle06imqcm/ToDWorldMapPolitical2.pdn?rlkey=xtwfhkp4jn5mekk2wwksao9sr&e=1&st=9tznt5gs&dl=1 Thanks Quote Link to comment Share on other sites More sharing options...
