NoahImposter Posted October 21 Share Posted October 21 I worked on a project a few months ago and recently found an issue with the text on the image being covered so I wanted to fix it, but I could not find the font. I also realized that some of the fonts that I used to use all the time aren't there. For example, the franklin fonts and the eras (can't remember the exact name) fonts. Would it be possible that it hid some of the fonts? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted October 21 Share Posted October 21 Is it possible you used a different machine to do the edits? Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
NoahImposter Posted October 21 Author Share Posted October 21 I know I used paint.net, I remember making it. I also saved it as a PDN. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted October 21 Share Posted October 21 Do other applications (Word, etc.) show the font that is missing from Paint.NET? Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
NoahImposter Posted October 21 Author Share Posted October 21 I checked Microsoft Word and it does, I could only find one on google docs. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted October 21 Share Posted October 21 Make sure the fonts are installed properly for all users: https://forums.getpaint.net/topic/121343-boltbaits-gpu-accelerated-plugin-pack-for-paintnet-v50-updated-2023-07-28/?do=findComment&comment=611760 If you've tried that and are still having problems, tell us one of the missing font names and where to download it. Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
NoahImposter Posted October 21 Author Share Posted October 21 I didn't personally install the fonts as they came with paint.net, but are now gone. To get them back, would I have to install them like you somewhat said above? Quote Link to comment Share on other sites More sharing options...
Solution Tactilis Posted October 21 Solution Share Posted October 21 2 hours ago, NoahImposter said: I didn't personally install the fonts as they came with paint.net, but are now gone. You are mistaken. Paint.NET does not install any fonts. It uses whatever fonts you have installed. 1 Quote Link to comment Share on other sites More sharing options...
Pixey Posted October 21 Share Posted October 21 9 hours ago, NoahImposter said: For example, the franklin fonts and the eras (can't remember the exact name) fonts. Would it be possible that it hid some of the fonts? Please check your Fonts on your computer - this is where they are stored and is where you add fonts. This is where paint.net goes to when you are in the program. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
BoltBait Posted October 21 Share Posted October 21 6 hours ago, Tactilis said: Paint.NET does not install any fonts. This is correct. Paint.NET does not come with any fonts. It simply uses the fonts you already have installed on your system. If you need some more fonts, try dafonts.com Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
NoahImposter Posted October 23 Author Share Posted October 23 Thank you all so much for your help. Quote Link to comment Share on other sites More sharing options...
