Lord Destro Posted June 1 Share Posted June 1 Good morning. I am trying to color in the belt of these football pants, but haven't figured out how to do so. I'm a novice in editing and asking for help in how to pull this off. One of the pictures below is the belt itself that I'm trying to color in. The other is the ending result I'm trying to achieve. Thank you in advance. Quote Link to comment Share on other sites More sharing options...
Pixey Posted June 1 Share Posted June 1 1. Make a new layer and change the Mode to Multiply. 2. Paint over the area you want to change. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Lord Destro Posted June 2 Author Share Posted June 2 11 hours ago, Pixey said: 1. Make a new layer and change the Mode to Multiply. 2. Paint over the area you want to change. I tried this route, but I just don't have the steady hand to trace around the buckle. I was hoping there was an easier technique. Quote Link to comment Share on other sites More sharing options...
Solution Disk4mat Posted June 2 Solution Share Posted June 2 You kinda solved your own problem. Without knowing it... The image on the right, work with that one. Open it in PDN and go to the Adjustments Menu, Hue / Saturation... Then slide Hue level to the right or left and it will change the color of the belt and Swoosh logo. Fine tune it to your preferred color and your done. You can do this for other colored parts of the uniform. Get all your images together and reuse the same Hue setting for all of them. Quote Link to comment Share on other sites More sharing options...
Lord Destro Posted June 2 Author Share Posted June 2 17 minutes ago, Disk4mat said: You kinda solved your own problem. Without knowing it... The image on the right, work with that one. Open it in PDN and go to the Adjustments Menu, Hue / Saturation... Then slide Hue level to the right or left and it will change the color of the belt and Swoosh logo. Fine tune it to your preferred color and your done. You can do this for other colored parts of the uniform. Get all your images together and reuse the same Hue setting for all of them. Why didn't I think of this beforehand? lol Thanks, man. 1 Quote Link to comment Share on other sites More sharing options...
Disk4mat Posted June 2 Share Posted June 2 Its hard to think of every feature and all the things you can do. Thats what makes this forum great. When your all done with your uniform you have to show us how it turned out. Quote Link to comment Share on other sites More sharing options...
Lord Destro Posted June 2 Author Share Posted June 2 3 minutes ago, Disk4mat said: Its hard to think of every feature and all the things you can do. Thats what makes this forum great. When your all done with your uniform you have to show us how it turned out. Will do. Quote Link to comment Share on other sites More sharing options...
