treasuresintroves3d Posted October 12, 2022 Share Posted October 12, 2022 I want to copy the middle red one and the purple one and others like it. You can see my best tries but they are not as good. Any suggestions would help a lot. Basically I copy the black parts and use the outline plugin. Then make the outline transparent. His it better by far. image below https://ibb.co/SJWmjP8 Quote Link to comment Share on other sites More sharing options...
Pixey Posted October 12, 2022 Share Posted October 12, 2022 Hello @treasuresintroves3d and welcome You could do this. 1. Draw your emblem on a transparent layer. 2. Duplicate it and fill it with another color. 3. Move it underneath the original layer. 4. Gaussian blur. 5. Duplicate the blurred layer for a stronger color. < clickable > Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
treasuresintroves3d Posted October 12, 2022 Author Share Posted October 12, 2022 That really did make it look a lot more like his!!! THANKS! Take a look. Now that being said, Any idea how he got it to get similar effects like the parts circled in red on the second picture? https://ibb.co/sK9tB7m https://ibb.co/6FcKpsT Quote Link to comment Share on other sites More sharing options...
NinthDesertDude Posted October 12, 2022 Share Posted October 12, 2022 Use the brush tool and draw on a layer below the emblem to create irregularity in the shape. Use the same color as the glow so it matches. Probably want to thin the glow on the original layer in a few places by using the eraser tool, too Quote Link to comment Share on other sites More sharing options...
Solution Pixey Posted October 12, 2022 Solution Share Posted October 12, 2022 3 minutes ago, treasuresintroves3d said: Any idea how he got it to get similar effects like the parts circled in red You could use the Smudge Tool Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
treasuresintroves3d Posted October 13, 2022 Author Share Posted October 13, 2022 GODS AMONG PAINT.NET USERS! Quote Link to comment Share on other sites More sharing options...
