Easy way to match color in Paint.NET?
2 hours ago, toe_head2001 said:
Why's that? What happened when you tried to use it?
Oh, I saw the plugin was from 2008 and just thought It wouldn't work maybe because it's too old and outdated
Just checked and the plugin works fine. My bad about that.
However, I can't get the result I want with it.
I want to make this one down here :arrow-down:
to have the same color tone as this one :arrow-down: (Maybe a little bit bluer?)
But I get this as a result when I "match color" with that plugin;
I've tried manually adjusting the color tone using one of BoltBait's plugins but I couldn't get them to have the same color tone by myself. Would there be any way to do this?
Thanks in advance :)
If you don't aim for an EXACT match, then you'll be able to get good results without any plugins.
Try using Curves or Hue / Saturation under the Adjustments menu. More here (<- click).
(I'd post my results but then I don't know how much you mean my "a little bit").
Yep, I just used that to get a satisfactory result. Thanks for the advice 🙂
