Foxxey Posted May 8, 2020 Share Posted May 8, 2020 (edited) So basically this simple plugin generates a random sound wave. Thats it! To install it extract the zip file and execute the .bat file. To install it manually drag and drop the .dll file into your Effects folder. Location: Effects>Render Example: https://prnt.sc/sd0gr3 SoundWave.cs SoundWave.zip Edited June 29, 2020 by Foxxey 2 1 Quote Link to comment Share on other sites More sharing options...
Djisves Posted May 8, 2020 Share Posted May 8, 2020 Thank you @Foxxey. SoundWave with Polar Inversion: 1 2 Quote Link to comment Share on other sites More sharing options...
Foxxey Posted May 8, 2020 Author Share Posted May 8, 2020 Just now, Djisves said: Thank you @Foxxey. SoundWave with Polar Inversion: Wow! This is really cool looking! Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted May 8, 2020 Share Posted May 8, 2020 The title is misleading. I thought this was going to generate a graphical waveform representation from a audio file. This have nothing to do with sound. I would recommend changing the name to 'Random Waveform', or something like that. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Foxxey Posted May 8, 2020 Author Share Posted May 8, 2020 3 hours ago, toe_head2001 said: The title is misleading. I thought this was going to generate a graphical waveform representation from a audio file. This have nothing to do with sound. I would recommend changing the name to 'Random Waveform', or something like that. its in the description though. Quote Link to comment Share on other sites More sharing options...
