Pit Posted October 17, 2019 Share Posted October 17, 2019 Hi paint.net Community, i have a Problem to install a Plugin. Any todos i can find, shows a Programm Path like " c:\Program Files\Paint.Net\..." and for Filetypes the Subfolder "FileTypes". I want to use RAW-Files in Paint.Net and have it install as Admin with Admin Privileges (to use for all Users). The Install-Path is ""C:\Program Files\WindowsApps\dotPDNLLC.paint.net_4.205.7213.0_x64__h55e3w7q8jbva" and tere is a Subfolder""C:\Program Files\WindowsApps\dotPDNLLC.paint.net_4.205.7213.0_x64__h55e3w7q8jbva\Bundled" with "DDSFileTypePlus" and WebPFileType. I do this as Admin but i cant create a new Subfolder there. I have test with Powershell as Admin, Explorer as Admin, but all times it comes "access denied" and i cant create the Subfolder. Change the Folder from Owner "system" to "Administrator" do not help. The System is Windows 10 Pro 64 (10.0.18362 Build 18362) on a Dell core I7 with 16 RAM, 512 SSD. I have Pant.Net paid at the Microsoft Homepage and I want to use the Plugin "RAW FileType (2018-06-14)". Please help me to use RAW (Olympus ORF-Files). Thank you in advance and best regards Pit Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 17, 2019 Share Posted October 17, 2019 https://www.getpaint.net/doc/latest/InstallPlugins.html#4 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
HyReZ Posted October 17, 2019 Share Posted October 17, 2019 @PitI use the Olympus PEN E-PL1 that creates RAW files as ORF images. To get the ORF images icon to appear as image thumbnails and open in Windows Viewers you will need to install the RAW CODEC for Windows. Here is a link to the CODEC and information about it:https://www.microsoft.com/en-US/Download/details.aspx?id=26829 1 Quote Link to comment Share on other sites More sharing options...
Pit Posted October 17, 2019 Author Share Posted October 17, 2019 @HyReZ Thank you, but that's not my problem. The Windows RAW, HEIC etc. plugins all work. In Paint.Net I get but no plugins loaded. The installation as an app is new territory for me. The installation is also totally hidden and not in the programs. Quote Link to comment Share on other sites More sharing options...
Pit Posted October 17, 2019 Author Share Posted October 17, 2019 @toe_head2001Thank you, under Windows itself, I have already installed the appropriate codecs. In Paint.Net I can not open RAW files and I do not get any plugins installed for this. Paint.Net was installed as an app, not a program. Quote Link to comment Share on other sites More sharing options...
HyReZ Posted October 17, 2019 Share Posted October 17, 2019 (edited) The link that toe_head2001 provided explains where and how to create folders and sub-folders to place the effects, filetypes, and shapes plugins into. Read the second yellow highlighted not from his link about creating folders for effects and filetypes for the store version of Paint.NET If you are novice to Windows and you do not know how to create folders here is a tutorial link: Edited October 18, 2019 by HyReZ to add more nfo and clarification Quote Link to comment Share on other sites More sharing options...
HyReZ Posted October 17, 2019 Share Posted October 17, 2019 1 hour ago, Pit said: @toe_head2001Thank you, under Windows itself, I have already installed the appropriate codecs. In Paint.Net I can not open RAW files and I do not get any plugins installed for this. Paint.Net was installed as an app, not a program. All apps are programs. Computer Program From Wikipedia, the free encyclopedia "A computer program is a collection of instructions that performs a specific task when executed by a computer. Most computer devices require programs to function properly." https://en.wikipedia.org/wiki/Computer_program Quote Link to comment Share on other sites More sharing options...
SodiumEnglish Posted October 19, 2019 Share Posted October 19, 2019 On 10/17/2019 at 7:41 PM, HyReZ said: All apps are programs. There is a distinction between the standard free 'program' as he put it and the Windows Store 'app'. The issue here is about correctly installing plugins when using the Windows Store version. It is clear he is using the Windows Store 'app' version by the WindowsApps folder in the install path he gave. @Pit The link that @toe_head2001 provided gives the correct instructions but it doesn't sound like you correctly solved the problem. Trying to install to the Program Files or WindowsApps locations when using the Windows Store version will not work and you won't see any plugins you attempt to install. You need to create folders in your My Documents as the link states and place your plugins there to correctly use plugins with the Windows Store version. Quote Link to comment Share on other sites More sharing options...
HyReZ Posted October 19, 2019 Share Posted October 19, 2019 Now that Pit as seen the information for installing the plugins for Paint.NET by 3 sources they can now do it. 1 hour ago, SodiumEnglish said: It is clear he is using the Windows Store 'app' version by the WindowsApps folder in the install path he gave. It was clear to me also when I agreed with toe_head2001 and referred Pit to go back to the link and its second yellow highlight note on how to create the /paint.net App folder and its sub-folders in the My Documents folder. I also include a video link on how to create and place a folder in Windows just in case PIt was a novice to this procedure. Now we can all wait and see if any of this advice helped!? 1 Quote Link to comment Share on other sites More sharing options...
Pit Posted October 27, 2019 Author Share Posted October 27, 2019 Thank you, I lift the three directories created and saved the plugin under "C: \ Users \ peter \ Documents \ paint.net App Files \ FileTypes". Works flawlessly. Now I am still looking for something nice dramatic effects and to insert watermarks. I am excited, thank you! Quote Link to comment Share on other sites More sharing options...
HyReZ Posted October 27, 2019 Share Posted October 27, 2019 I created a variety of custom watermarks and save them to a transparent layer. I can open and apply them as needed as well as alter their color and opacity and even re-scale them as it suites the project. Best Wishes! Quote Link to comment Share on other sites More sharing options...
