KeyLogic Posted August 17, 2008 Share Posted August 17, 2008 I used the "Engrave / Emboss..." effect on an oddly shaped object but now I want to completely remove, or rather make completely transparent, one of the colors, in this case Grey. I've already tried using the Alpha Mask to little avail. (1) I need to make the Grey completely transparent without affecting the Black and White. (2) I want to change the Black or white to a color. How can I achieve this? :? Quote KeyLogic's Art Gallery My deviantART Profile Link to comment Share on other sites More sharing options...
Simon Brown Posted August 17, 2008 Share Posted August 17, 2008 Try this: viewtopic.php?f=16&t=25155 :wink: Quote Link to comment Share on other sites More sharing options...
KeyLogic Posted August 17, 2008 Author Share Posted August 17, 2008 I did. Maybe I'm not making to proper adjustments or something. It either wants to remove the Black or Remove the White, never just the Grey. Edit: OK, I think that I may have got it to work. Thank you. Now, this should be a lot easier to do. I need to darken the White color so that it's slightly Grey-ish and lighten the Black color so that it's dark Grey, all without affecting the semi-transparent edges . Basically it would work like the Condition Hue/Saturation effect but for Black, White and Grey. Have any ideas anyone? Quote KeyLogic's Art Gallery My deviantART Profile Link to comment Share on other sites More sharing options...
Mike Ryan Posted August 17, 2008 Share Posted August 17, 2008 Use Brightness/ Contrast by lowering the Contrast. IIRC that makes everything a bit more greyer Quote Link to comment Share on other sites More sharing options...
