Hard Posted March 10, 2018 Share Posted March 10, 2018 Hello all, I have a bit of an issue. I created an advertising design for print on paint.net, but it turns out that I created it on too low of a resolution (996x1342, 95.99 ppi). If I increase the ppi to 300, the print size would be 3.32x4.47 inches, which is too small. Is there a way to either move my layers onto a new canvas with a higher resolution or am I out of luck? As you can probably tell, I'm pretty new at this, so I apologize if this is a novice question. Thank you in advance. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted March 10, 2018 Share Posted March 10, 2018 (edited) Hello Hard, welcome to the forum Without seeing your image, its hard to tell if resizing would work. You could try it: 1. Open the Resize dialog (Ctrl+R) 2. Check the "By Absolute Size"radio button 3. Check the Maintain aspect ration checkbox 4. Change the Resolution to 300 + pixels/inch 5. increase the width until l you get your desired print size shown in the Print Size Edited July 4, 2018 by toe_head2001 Fixed broken Postimg image Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
