3doutlaw 0 Posted January 15, 2018 Share Posted January 15, 2018 I am wondering if there is a plugin or a good method for creating speed lines or zoom lines, as would be seen in a comic. This is an extension for Photoshop that has a good description of what I was looking for. https://www.behance.net/gallery/30884153/Comic-Effect-Kit-(Photoshop-Add-ons) Thanks! Quote Link to post Share on other sites
toe_head2001 1,868 Posted January 15, 2018 Share Posted January 15, 2018 With a little configuration, the Light Rays plugin can do the "Zoom Lines". Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
3doutlaw 0 Posted January 15, 2018 Author Share Posted January 15, 2018 Yea, I did try that one, but it did not allow control of the thickness of the lines. You could only get thinner lines by adding more lines, or the ratio setting, which made them uneven. Thanks for the idea though! Quote Link to post Share on other sites
toe_head2001 1,868 Posted January 15, 2018 Share Posted January 15, 2018 3 minutes ago, 3doutlaw said: You could only get thinner lines by adding more lines, or the ratio setting, which made them uneven. Ok, so run the effect more than once. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
3doutlaw 0 Posted January 15, 2018 Author Share Posted January 15, 2018 OK, I must be missing a setting, cause I couldn't get the lines thin like that when using only 25. I must be missing something. Back in a few after I re-attempt! Quote Link to post Share on other sites
3doutlaw 0 Posted January 15, 2018 Author Share Posted January 15, 2018 OK, I got that, thanks! The bottom is the Ratio, and that can thin the lines, and use the top for the rotation angle. When I was doing those before, I was dialing both, and my screen update was giving me odd results. I've updated PDN since that, and it works better. That'll work for the one! Quote Link to post Share on other sites
3doutlaw 0 Posted January 15, 2018 Author Share Posted January 15, 2018 Found this on the web via google just now from 2012 (link). Tried it and it gets more random results, but less option to move the center... drag across edge of picture a small area fill with noise drag that area across the picture to make random lines Rect to Polar using plugin White/Trans gradient on another layer from middle duplicate layer as needed See below Stop at #3 for zoom lines. These two solution should work for me, thanks for the help! Quote Link to post Share on other sites
MadJik 973 Posted January 15, 2018 Share Posted January 15, 2018 1. Bars 2. Polar 3. Zoom blur + repeat as needed 1 Quote My DeviantArt | My Pictorium | My Plugins | Donate via Paypal Link to post Share on other sites
3doutlaw 0 Posted January 22, 2018 Author Share Posted January 22, 2018 Nice thanks, that's easier! Quote Link to post Share on other sites
