ChuckK Posted February 1, 2016 Share Posted February 1, 2016 I get this error when installing latest version: "There was an error while installing paint.net (1602)" & their is also a "fatal error" msg displayed. Do not know what it means or how to correct. Thanks Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted February 1, 2016 Share Posted February 1, 2016 Hey ChuckK - welcome to the forum We'll need more information... What version are you trying to install? What version did you have previously? Tell us your system specifications. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
ChuckK Posted February 24, 2016 Author Share Posted February 24, 2016 paint.net 4.0.9 I was using the version before this. Do not remember version number. Sys Info: Windows 10 Home 64 Bit OS 24 Gig Ram Intel Core i7-4790 CPU @ 3.60 GHz Dual Drive---------------------------------- C: 240 Gig Solid State D: 2 Terabyte HD Older installed version was installed over D: drive root directory (Should not have beer when installing programs) not in a separate directory. . Any help would be appreciated mate! Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted February 24, 2016 Share Posted February 24, 2016 Got here http://forums.getpaint.net/index.php?/topic/692-install-update-or-uninstall-trouble-read-this/ Read post #2 about the Windows Installer CleanUp utility. Use that or Revo Uninstaller to remove the previous installation. Then try a fresh install to the default location. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
