DaveD Posted January 1, 2008 Share Posted January 1, 2008 Problem: When using the Fixed Ratio selection tool of 16:10 to make a selection, all of the buttons in the floating Tools bar do not show the text when hovering the mouse above. The text does appear when hovering over the regular toolbar buttons. This only appears to affect the floating Tools buttons. Reproducible: Always. Step to reproduce: - Square selection tool - Select Fixed Ratio - Width: 16 Height: 10 - Select any area of image - Hover mouse over floating Tools buttons I tried this with 4:3 which is default and it does not cause this problem. FIX: To get the hover text back, you have to restart Paint.NET because closing the image or creating a new image does not bring the hover text back. Quote Link to comment Share on other sites More sharing options...
Zagna Posted January 1, 2008 Share Posted January 1, 2008 I just tried this and it isn't related to 16:10. You can set it to fixed size or ratio and just change either value and the Tools tips disappear. Quote Link to comment Share on other sites More sharing options...
I Like Pi Posted January 1, 2008 Share Posted January 1, 2008 Seems like giving focus to any of the textboxes causes it, even if you don't change anything. It doesn't happen with the drop down textboxes like brush width though. Quote Link to comment Share on other sites More sharing options...
DaveD Posted January 5, 2008 Author Share Posted January 5, 2008 Now whether this is specific to 16:10 or not, it certainly is becoming more and more of a problem with me when using Paint.NET since I have been cropping images and creating backgrounds. For a seasoned Paint.NET user, this may not be such an issue. However, I was left trying to guess what each of the buttons on the Tools menu did. So for a newer user of Paint.NET, this is definitely a problem. Is this recognized as a bug? Is there a bug report already filed? Thanks, Dave Quote Link to comment Share on other sites More sharing options...
Myrddin Posted January 5, 2008 Share Posted January 5, 2008 In the meantime, all the functions along the top can be found in the menus above, with permanent labels, and the tools can be found in the dropdown menu found to the left on the last row before the canvas, just here: It may not be ideal, but whilst this is still problematic for you it may help. Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
