ImJustaNoob Posted July 16, 2007 Share Posted July 16, 2007 is there any way at all that by using the 3d cube that you can put two or three different images on each side? Quote "JustaNoobs about to BustAMove!" -commandersozo Link to comment Share on other sites More sharing options...
Ash Posted July 16, 2007 Share Posted July 16, 2007 I believe I answered here, check it out. http://paintdotnet.12.forumer.com/viewt ... 9781#59781 Hope this helps. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
ImJustaNoob Posted July 16, 2007 Author Share Posted July 16, 2007 uh, as my name says im just a noob. i don't get what he is saying there. it doesn't help that it is in Japanese either. im sorry can anyone else help me here? Quote "JustaNoobs about to BustAMove!" -commandersozo Link to comment Share on other sites More sharing options...
Ash Posted July 16, 2007 Share Posted July 16, 2007 There should be enought pic so even you don't understand Japanese you should be able to understand. Hint: Use "Dice map" Look at the 2nd and 3rd pic on MKT's site. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
ImJustaNoob Posted July 16, 2007 Author Share Posted July 16, 2007 ok thank you i got it. i had an older version of shape 3d. it didnt have the option to chose the face that i wanted the pic to be on. thanks a lot. Quote "JustaNoobs about to BustAMove!" -commandersozo Link to comment Share on other sites More sharing options...
davidtayhs Posted July 17, 2007 Share Posted July 17, 2007 Been using Paint.net for awhile but feel embarrassed to say despite going thru' MKT's website, I really still don't know how to place a picture on one of the sides. Wonder if it's because my shape3D plugin is the older version. Went to the website, downloaded it several times from the download link on the left column but still don't see any options to position pictures to the sides of a box. Having version 1.1.2.0. Guess I'm one of the few who probably needs a step by step tutorial! Could a kind soul (Ash?!) be a good Samaritan? Quote Link to comment Share on other sites More sharing options...
Ash Posted July 17, 2007 Share Posted July 17, 2007 Hmm, I will see what I can do Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
davidtayhs Posted July 18, 2007 Share Posted July 18, 2007 Hi Ash, Thanks for thinking about doing a tutorial. I've been trying it out in this way with some success: 1. Create a box using a 600x600 background (or other desired size) 2. Using a new layer with a picture of the same size, I now create an identical box with only one side specified e.g. top 3. Then creating another new layer with another picture of the same size, I now specify the new side of the box that I want the picture to be on. 4. Steps 2 & 3 are repeated as necessary to create all the different sides with different pictures as desired. 5. I delete the background 6. Flatten the image 7. The box appears with different pictures on different specified sides. Question: Is this how you do it with this plugin? The method I described is the only solution that I can think of! Only snag is that I've got to resize the images to the same size as the original background so that the shape3D plugin will create identical-sized box sides that will flatten correctly. Wonder if there's an easier way?!! Quote Link to comment Share on other sites More sharing options...
