welshred Posted June 20, 2007 Share Posted June 20, 2007 How do I get the font like the above? I have a similar font, but when I colour it, I can't get the red along the outside? Is there an easy way? Cheers Quote Link to comment Share on other sites More sharing options...
Ash Posted June 20, 2007 Share Posted June 20, 2007 Use search or just look at some topics http://paintdotnet.12.forumer.com/viewtopic.php?t=5327 This might help And checking out some tut might too. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
welshred Posted June 20, 2007 Author Share Posted June 20, 2007 Use search or just look at some topicshttp://paintdotnet.12.forumer.com/viewtopic.php?t=5327 This might help And checking out some tut might too. Thanks, I have looked in the Tutorials, and I will look in here.For some reason I tried that, and it didn't work as planned, I will have to try again... Quote Link to comment Share on other sites More sharing options...
welshred Posted June 20, 2007 Author Share Posted June 20, 2007 This is what I got... I need to find out how to make the yellow on the outside stand out a bit more? If anyone can help? //Shaun Quote Link to comment Share on other sites More sharing options...
Stephan Posted June 20, 2007 Share Posted June 20, 2007 Try duplicating the yellow layer, plus, white doesn't show half-transparent yellow very well Try a black background, or something else that's dark. Quote Link to comment Share on other sites More sharing options...
welshred Posted June 20, 2007 Author Share Posted June 20, 2007 I have found an easier way... Donwload the Drop Shadow plugin and use that, set the shadow colour to the one you want, hey presto. Thanks. Close Thread //Shaun Quote Link to comment Share on other sites More sharing options...
Stephan Posted June 20, 2007 Share Posted June 20, 2007 OK, i got the easiest way.Top layer: Red color text Bottom Layer: Yellow color text. On bottom laters. Use Glow, Glow again....and again....till you see the "outline" you want. Done Hope this helps. That's basically the same i said, but it will lighten the yellow, which we don't want since it is ALREADY a very light color. Quote Link to comment Share on other sites More sharing options...
welshred Posted June 20, 2007 Author Share Posted June 20, 2007 Oops, Thanks anyway... Quote Link to comment Share on other sites More sharing options...
