johnish Posted September 16, 2015 Share Posted September 16, 2015 I can't get paintbrush and pencil to work I select a colour on the colour wheel and the hold down Ctrl and move the cursor and absolutely nothing happens. I did it successfully at my first attempt last week and don't think I'm doing anything different. Your forum suggests resetting tools but I can't see how to do this the place suggested for doing it seems not to exist. - there's nothing between file/edit and Tool. John Presland Quote Link to comment Share on other sites More sharing options...
Pixey Posted September 16, 2015 Share Posted September 16, 2015 Are you sure you are on the paint brush tool and not on the magic wand by chance ? Also, no need to hold down the Ctrl to paint. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Cc4FuzzyHuggles Posted September 19, 2015 Share Posted September 19, 2015 (edited) You probably read a thread suggesting help for an older version of paint.net. In paint.net 4.0 you can reset the tools by clicking paint.net's settings icon in the upper right corner of the program, and then when in the settings dialog box click "tools", and then look for the "reset" button. Here is paint.net's documentation. Also, be sure you don't accidentally have an active selection on, de-select (ctrl + d) to remove any selections you might have. If you have a selection and want it to remain, then be sure to draw inside of the selection. Edited September 19, 2015 by Cc4FuzzyHuggles Quote *~ Cc4FuzzyHuggles Gallery ~* Link to comment Share on other sites More sharing options...
