toe_head2001 Posted January 23, 2015 Share Posted January 23, 2015 I'm not sure how this happened, so not able to reproduce. Basically many plugins, but not all, disappeared from the effects menu. I thought maybe something caused those plugins themselves to crash en masse. I click to open the setting dialog to see Plugin Errors, and that's when the whole program crashed. Personally, I blame gremlins. Spoiler This text file was created because paint.net crashed. Please e-mail this to crashlog4@getpaint.net so we can diagnose and fix the problem. Application version: paint.net 4.0.5 (Final 4.5.5454.39504) Time of crash: 1/22/2015 10:53:45 PM Application uptime: 12:12:44.6626349 Application state: Running Working set: 825,284 KiB Threads: 120 Install directory: C:\Program Files\Paint.NET Current directory: C:\Program Files\Paint.NET OS Version: 6.1.7601.65536 Service Pack 1 Workstation x64 .NET version: CLR 4.0.30319.18444 x64, FX 4.0 4.5 Processor: 6x "AMD FX-6300 Six-Core Processor " @ ~3500MHz (DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, XSAVE) Physical memory: 8140 MB Video card: AMD Radeon HD 7700 Series (v:1002, d:683D, r:0) Hardware acceleration: True (default: True) UI animations: True UI DPI: 96.00 dpi (1.00x scale) UI theme: Aero/Aero + DWM (Aero.msstyles) Updates: True, 1/22/2015 Locale: pdnr.c: en-US, hklm: en-US, hkcu: en-US, cc: en-US, cuic: en-US Flags: Exception details: System.ArgumentException: Parameter is not valid. at System.Drawing.Image.FromStream(Stream stream, Boolean useEmbeddedColorManagement, Boolean validateImageData) at PaintDotNet.Resources.PdnResources.LoadImage(Stream input) in d:\src\pdn\paintdotnet\src\Resources\PdnResources.cs:line 383 at PaintDotNet.Resources.PdnResources.GetImage(String fileName) in d:\src\pdn\paintdotnet\src\Resources\PdnResources.cs:line 273 at PaintDotNet.ImageResource.get_Reference() in d:\src\pdn\paintdotnet\src\Base\ImageResource.cs:line 39 at PaintDotNet.Settings.UI.UISettingsSection..ctor(AppSettings appSettings) in d:\src\pdn\paintdotnet\src\PaintDotNet\Settings\UI\UISettingsSection.cs:line 25 at PaintDotNet.Settings.UI.SettingsDialog..ctor(IServiceProvider services, AppSettings appSettings, ToolsSection toolBarSettings) in d:\src\pdn\paintdotnet\src\PaintDotNet\Settings\UI\SettingsDialog.cs:line 254 at PaintDotNet.Menus.PdnAuxMenu.ShowSettings() in d:\src\pdn\paintdotnet\src\PaintDotNet\Menus\PdnAuxMenu.cs:line 218 at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.MenuStrip.WndProc(Message& m) at PaintDotNet.SystemLayer.MenuStripEx.WndProc(Message& m) in d:\src\pdn\paintdotnet\src\SystemLayer\MenuStripEx.cs:line 57 at PaintDotNet.Menus.PdnAuxMenu.WndProc(Message& m) in d:\src\pdn\paintdotnet\src\PaintDotNet\Menus\PdnAuxMenu.cs:line 124 at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) Managed assemblies: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorlib.dll PaintDotNet, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe PaintDotNet.Core, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll PaintDotNet.Base, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.dll WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\WindowsBase\v4.0_4.0.0.0__31bf3856ad364e35\WindowsBase.dll PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\Microsoft.Net\assembly\GAC_64\PresentationCore\v4.0_4.0.0.0__31bf3856ad364e35\PresentationCore.dll System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll PaintDotNet.SystemLayer, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll PaintDotNet.Framework, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Framework.dll PaintDotNet.Resources, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll PaintDotNet.Data, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll PaintDotNet.Effects, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Effects.dll PaintDotNet.SystemLayer.Native.x64, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xaml\v4.0_4.0.0.0__b77a5c561934e089\System.Xaml.dll System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll "AA's_Assistant", Version=1.1.4329.33034, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AA's_Assistant.dll AdvancedRotate, Version=1.0.3663.28009, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AdvancedRotate.dll Alias, Version=2.0.3167.14578, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alias.dll AlignPlugin, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlignPlugin.dll Alpha2Gray, Version=4.0.5284.36690, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha2Gray.dll AlphaBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaBlur.dll AlphaContrast, Version=1.0.3813.18307, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaContrast.dll AlphaThreshold, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaThreshold.dll Alpha_to_0, Version=1.0.4452.22746, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha_to_0.dll Alpha_to_255, Version=1.0.4452.22782, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha_to_255.dll Asmageddon_Alpha works, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Alpha works.dll Asmageddon_Channel multiplier, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Channel multiplier.dll Asmageddon_Channel_Shift, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Channel_Shift.dll Asmageddon_Channel_Works_Plus, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Channel_Works_Plus.dll Asmageddon_Color_Percentage_Plus, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Color_Percentage_Plus.dll Asmageddon_From P to S Grey, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_From P to S Grey.dll Asmageddon_From P to S, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_From P to S.dll Asmageddon_HSV inversion, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_HSV inversion.dll Asmageddon_Hue Channeling multiply, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Hue Channeling multiply.dll Asmageddon_Hue Red Psychodelic, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Hue Red Psychodelic.dll Asmageddon_Image coder, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Image coder.dll Asmageddon_Inverto_pushing, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Inverto_pushing.dll Asmageddon_Inverto_pushing_Caleidoscope, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Inverto_pushing_Caleidoscope.dll Asmageddon_Inverto_pushing_plus, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Inverto_pushing_plus.dll Asmageddon_Multiplo uniqua, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Multiplo uniqua.dll Asmageddon_PS Mega, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_PS Mega.dll Asmageddon_PS Only, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_PS Only.dll Asmageddon_Pseudo water, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Pseudo water.dll Asmageddon_Quadro disorter B, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Quadro disorter B.dll Asmageddon_Quadro disorter, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Quadro disorter.dll Asmageddon_Render-Border, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Render-Border.dll Asmageddon_Render-Quadro bumperoo, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Render-Quadro bumperoo.dll Asmageddon_Render-Quadro inverto, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Render-Quadro inverto.dll Asmageddon_Render-Quadro sharper, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Render-Quadro sharper.dll Asmageddon_RGB tricks, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_RGB tricks.dll Asmageddon_Strange Bulger B, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Strange Bulger B.dll Asmageddon_Strange Bulger, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Strange Bulger.dll Asmageddon_Strange_Bulger Kaleidoscope, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Strange_Bulger Kaleidoscope.dll AutoChrome, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AutoChrome.dll AutoChromeNoise, Version=1.0.3847.37353, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AutoChromeNoise.dll Bars, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bars.dll BasicPhotoAdjustments, Version=2.1.4020.485, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BasicPhotoAdjustments.dll Basic Edge Detector, Version=2.0.5346.43075, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Basic_Edge_Detector.dll BevelObject, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BevelObject.dll Bevel, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bevel_v1.4.0.0.dll Bezncurve, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bezncurve.dll Bidirectional Blur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bidirectional Blur.dll BlackAndWhiteConverter, Version=1.1.3472.36275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Black and White Converter.dll BlackandAlpha+, Version=1.2.4329.272, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlackandAlpha+.dll "Borders N' Shapes", Version=4.0.4642.26476, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll Boutons, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Boutons.dll Burninate, Version=4.0.5284.36910, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Burninate.dll CalliColour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CalliColour.dll CameraLens, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CameraLens.dll CircleText, Version=1.4.4415.32488, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CircleText.dll ClipWarpNew, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClipWarpNew.dll Cobweb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Cobweb.dll CodeLab, Version=2.3.5341.33520, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CodeLab.dll Color Match, Version=4.0.4642.26532, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color Match.dll coloraberation, Version=1.0.3859.18981, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\coloraberation.dll ColorBalance, Version=4.0.5284.37112, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorBalance.dll ColorHarmonies.Effect, Version=0.7.0.155, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorHarmonies.Effect.dll ColorMixer, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorMixer.dll ColorModulo, Version=1.1.3643.38108, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorModulo.dll ColorToAlpha, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorToAlpha.dll ColorTrimming, Version=1.0.3167.14623, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorTrimming.dll ColorZoomBlur, Version=1.1.3873.36417, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorZoomBlur.dll Compotool, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Compotool.dll Contour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Contour.dll LightningCurve, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurlyLines.dll CurtisBlack.Common, Version=1.0.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Common.dll CurtisBlack.Effects, Version=11.1.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Effects.dll CurtisBlack.Resources, Version=1.0.3490.22409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Resources.dll Curves+, Version=4.0.4642.26561, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Curves+.dll CustomBrushesMini, Version=2.2.5286.39584, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll Displacement, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Displacement.dll DistortingMirror, Version=1.0.4281.30602, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DistortingMirror.dll Donut, Version=1.0.4354.32246, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Donut.dll dpyColorBalance, Version=1.1.4330.37850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\dpyColorBalance.dll DragFrom, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DragFrom.dll Dream, Version=4.1.5307.24374, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dream.dll Dryad, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dryad.dll EarthsAndGreys, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EarthsAndGreys.dll EdHarvey.Effects, Version=4.0.5120.42730, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll EditableText, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EditableText.dll EngraveEmboss, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EngraveEmboss.dll EOEffects, Version=1.10.16.12, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EOEffects.dll ExtendBorder, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ExtendBorder.dll Eyeshine, Version=1.0.3700.25905, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Eyeshine.dll FillFromClipboard, Version=4.0.5286.32881, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FillFromClipboard.dll FillFromFile, Version=4.0.5286.32800, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FillFromFile.dll Film, Version=4.0.4642.26607, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Film.dll FindEdges, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FindEdges.dll Flip, Version=4.0.5284.37716, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flip.dll FloydSteinbergDithering, Version=1.0.5321.25313, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FloydSteinbergDithering.dll Frames, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Frame.dll FurBlur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FurBlur.dll GaussianBlurPlus, Version=3.5.4315.35054, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GaussianBlurPlus.dll Gears, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gears.dll GenTree, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GenTree.dll Gradient Bars, Version=4.0.5152.23084, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Bars.dll Gradient Blocks, Version=4.0.4642.26658, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blocks.dll GradientBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blur.dll Gradient Mapping, Version=4.0.4642.26687, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll GradientsGalore, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GradientsGalore.dll Grain, Version=1.0.3854.25523, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Grain.dll Gravity, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gravity.dll Gray2Alpha, Version=4.0.5284.37903, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gray2Alpha.dll Grid Warp, Version=4.0.5149.26776, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Grid Warp.dll GridCheckerboard, Version=3.0.5297.18928, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridCheckerboard.dll GridMaker, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridMaker.dll GrimColorReaper, Version=1.2.4299.5808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GrimColorReaper.dll Helix, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Helix.dll HexaGrid, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HexaGrid.dll Highlight, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Highlight.dll HSVGradients, Version=3.0.5299.30308, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HSVGradients.dll HueSatPlus, Version=4.1.5333.37244, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HueSatPlus.dll IniFile, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IniFile.dll InputToOutput, Version=1.0.3167.14695, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InputToOutput.dll InvertAlpha, Version=1.0.3040.33378, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InvertAlpha.dll iPhoneTabbarIconMaker, Version=1.0.3659.22550, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\iPhoneTabbarIconMaker.dll PDNPI_IndirectUI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\jchunn.dll Jitter, Version=4.0.4642.26986, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Jitter.dll KaleidoGen, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\KaleidoGen.dll Kaleidoscope, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll Landscape, Version=4.0.5284.38226, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Landscape.dll Lens, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Lens.dll LensFlare, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LensFlare.dll LightRays, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LightRays.dll Liquify, Version=4.0.4642.26973, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Liquify.dll LocalContrast, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LocalContrast.dll Magnifier, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Magnifier.dll Majority, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Majority.dll Matrice, Version=1.0.3810.11744, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Matrice.dll Metallize, Version=1.2.4415.32969, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Metallize.dll MirrorRotate, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MirrorRotate.dll MirrorRotateMenu, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MirrorRotateMenu.dll Moire, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Moire.dll MotionSharpen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MotionSharpen.dll MultiThreshold, Version=1.1.4330.38982, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MultiThreshold.dll Nebulous, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Nebulous.dll NewtonFractal, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NewtonFractal.dll NoiseChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NoiseChoice.dll Object2Colour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Object2Colour.dll ObjectEdge, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Objectedge.dll ObjectFeather, Version=4.0.5284.38364, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ObjectFeather.dll Oblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Oblique.dll Olden, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Olden.dll Feather, Version=2.3.4315.37038, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OldFeather.dll Outline Object, Version=4.0.4642.26954, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline Object.dll OutlineObject, Version=1.1.3160.31739, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline.dll Overblur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Overblur.dll Overliner, Version=1.2.3888.29226, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Overliner.dll PageCurl, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PageCurl.dll PaletteFromImage, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PaletteFromImage.dll Panelling, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Panelling.dll PasteAlpha, Version=4.0.5284.38515, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PasteAlpha.dll Pastel, Version=4.0.5284.38621, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pastel.dll PDNPalette, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PDNPalette.dll PerlinTexture, Version=1.1.3857.30918, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PerlinTexture.dll Perspective, Version=2.1.4415.36116, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Perspective.dll PhotoAdjustments, Version=4.0.5284.38689, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PhotoAdjustments.dll Pixelate+, Version=4.0.4642.26940, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pixelate+.dll PlugInData, Version=1.0.2.10493, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PlugInData.dll Polar, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polar.dll PolariodFrame, Version=1.0.3171.27990, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PolariodFrame.dll Polygon, Version=4.0.5284.38954, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygon.dll Polygones, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygones.dll PrinterPlus, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PrinterPlus.dll Psychocolour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Psychocolour.dll pxEexpansion, Version=1.0.4437.36287, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\pxEexpansion.dll Radialcolors, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Radialcolors.dll RainbowTwist, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RainbowTwist.dll Random Effect, Version=4.0.4642.26928, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Effect.dll RandLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random lines.dll RandMaze1, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Maze1.dll RandMaze2, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Maze2.dll Random Shape Fill, Version=4.0.4642.26910, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll RecolourChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RecolourChoice.dll RedEyeQuickFix, Version=1.1.3161.39688, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RedEyeQuickFix.dll RemoveBrightDark, Version=1.1.3063.36415, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RemoveBrightDark.dll RemoveDust, Version=4.0.5284.39560, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RemoveDust.dll ReverseColors, Version=1.0.4121.15722, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ReverseColors.dll ReverseFisheye, Version=1.0.5146.21351, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ReverseFisheye.dll RGB_Remap4, Version=1.0.3538.24311, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RGB_Remap4.dll Rosaces, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rosaces.dll RotateText, Version=1.1.4415.32628, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotateText.dll RotateTextSUI, Version=1.1.4415.32713, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotateTextSUI.dll Rotate_Zoom+, Version=1.11.5237.17779, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rotate_Zoom+.dll SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SBCommon.dll Scintillate, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Scintillate.dll Scribble, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Scribble.dll ScriptLab, Version=4.0.5146.23014, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScriptLab.dll SeamlessTextureMaker, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll Selection2Clear, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Selection2Clear.dll SelectionObscure, Version=1.1.4602.34476, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionObscure.dll SelectionTools, Version=4.0.5284.39819, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionTools.dll ShadowEffect, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ShadowEffect.dll ShadowHighlight, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ShadowHighlight.dll Shape3D, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shape3D.dll Shapes, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shapes.dll Sharpen+, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sharpen+.dll silhouetteplus, Version=1.1.3131.17586, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\silhouetteplus.dll SinWaves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SinWaves.dll Slinky, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Slinky.dll Smooth, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smooth.dll Smudge, Version=4.0.4642.26844, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smudge.dll Sparkles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sparkles.dll SpeechBubble, Version=2.1.4445.42029, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpeechBubble.dll Spiral, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Spiral.dll SpiralText, Version=1.4.4415.32775, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiralText.dll SpiroGraph, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroGraph.dll SpiroShapes, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroShapes.dll Splashes, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splashes.dll Splatter, Version=4.0.4642.26829, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splatter.dll Squirkle, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Squirkle.dll SquirkleWarp, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SquirkleWarp.dll StarGlow, Version=1.0.3839.21249, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StarGlow.dll Stars, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stars.dll Stitch, Version=4.0.4642.26808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stitch.dll StringAndPin, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StringAndPin.dll TextPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Textplus.dll Tiles, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tiles.dll Trail, Version=4.0.4642.26791, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Trail.dll Transparency, Version=4.0.5284.39911, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transparency.dll TreeGen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TreeGen.dll TRsCustomRandomFill, Version=1.4.7.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCustomRandomFill.dll TRsFilmStock, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFilmStock.dll TubeOblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TubeOblique.dll Twist, Version=4.0.4642.26767, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Twist.dll TwistZ, Version=1.1.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwistZ.dll TwoToneThreshold, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwoToneThreshold.dll Vandermotten.PaintDotNetEffects.Blurs, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll Vandermotten.PaintDotNetEffects.ColorAccent, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll Vandermotten.PaintDotNetEffects, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.dll Vandermotten.PaintDotNetEffects.DropShadow, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll Vandermotten.PaintDotNetEffects.Duotones, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll Vandermotten.PaintDotNetEffects.FadeEdge, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll Vandermotten.PaintDotNetEffects.Gradient, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll Vandermotten.PaintDotNetEffects.Grid, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Grid.dll Vandermotten.PaintDotNetEffects.Monochromes, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll Vibrato, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vibrato.dll VignettePlus, Version=4.0.5284.40018, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\VignettePlus.dll Volutes, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Volutes.dll WaterReflection, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaterReflection.dll Waves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Waves.dll WaveText, Version=1.2.4415.32811, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaveText.dll WaveTextSUI, Version=1.2.4415.33440, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaveTextSUI.dll WetFloor, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WetFloor.dll XYCoords, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\XYCoords.dll OptionBasedLibrary v0.7.3, Version=0.7.0.229, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\OptionBasedLibrary v0.7.3.dll System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Design\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Design.dll Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Microsoft.VisualBasic\v4.0_10.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll WindowsFormsIntegration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\WindowsFormsIntegration\v4.0_4.0.0.0__31bf3856ad364e35\WindowsFormsIntegration.dll Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Accessibility\v4.0_4.0.0.0__b03f5f7f11d50a3a\Accessibility.dll IcoCur, Version=3.7.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\IcoCur.dll PaintShopProFiletype, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PaintShopProFiletype.dll System.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Security\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Security.dll p5enuevm, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ Microsoft.GeneratedCode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ <Location?> CAR.Paint.NET, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CAR.Paint.NET.dll.old Native modules: C:\Program Files\Paint.NET\PaintDotNet.exe, version=4.5.5454.39504 C:\Windows\SYSTEM32\ntdll.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\SYSTEM32\MSCOREE.DLL, version=4.0.40305.0 (Main.040305-0000) C:\Windows\system32\KERNEL32.dll, version=6.1.7601.18015 (win7sp1_gdr.121129-1432) C:\Windows\system32\KERNELBASE.dll, version=6.1.7601.18015 (win7sp1_gdr.121129-1432) C:\Windows\system32\ADVAPI32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\msvcrt.dll, version=7.0.7601.17744 (win7sp1_gdr.111215-1535) C:\Windows\SYSTEM32\sechost.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\RPCRT4.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\system32\SHLWAPI.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\GDI32.dll, version=6.1.7601.18577 (win7sp1_gdr.140822-1508) C:\Windows\system32\USER32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\LPK.dll, version=6.1.7601.18177 (win7sp1_gdr.130605-1534) C:\Windows\system32\USP10.dll, version=1.0626.7601.18454 (win7sp1_gdr.140424-1533) C:\Windows\system32\IMM32.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\MSCTF.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.0.30319.18444 built by: FX451RTMGDR C:\Windows\system32\MSVCR110_CLR0400.dll, version=11.00.50938.18408 built by: FX451RTMGREL C:\Windows\assembly\NativeImages_v4.0.30319_64\mscorlib\abf62e6545d2802fc60286678a67e6bf\mscorlib.ni.dll, version=4.0.30319.18444 built by: FX451RTMGDR C:\Windows\system32\ole32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\CRYPTBASE.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\uxtheme.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\assembly\NativeImages_v4.0.30319_64\System\3f4e05b74a222eaf142391c0549efe62\System.ni.dll, version=4.0.30319.34238 built by: FX452RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Drawing\33b0d91fe3a676b18649630b575bfe36\System.Drawing.ni.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\assembly\NativeImages_v4.0.30319_64\WindowsBase\7d6aa58b36b07ad1397d24d37e55f81f\WindowsBase.ni.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\system32\CRYPTSP.dll, version=6.1.7601.18526 (win7sp1_gdr.140706-1506) C:\Windows\system32\rsaenh.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\assembly\NativeImages_v4.0.30319_64\PresentationCore\147b9d59c55933d29db29b839cf52026\PresentationCore.ni.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\8c616047f194ff0ec4e8f2ffd68a268b\PresentationFramework.ni.dll, version=4.0.30319.18408 C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Core\2e9352fa8533dc500b03b97e5d3193c2\System.Core.ni.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Base\ba7c687b97315e744c35eabba558ae60\PaintDotNet.Base.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\765e2a5dac4d62213d49240acb13755b\System.Windows.Forms.ni.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\58b961c9baf4dda0dc026bc205ec2551\PaintDotNet.SystemLayer.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Core\6311bcb2c3da1837121f5fd337f35ef4\PaintDotNet.Core.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\e67a928c698a3364a97b057eb1cfd4d0\PaintDotNet.Resources.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\1fe6bc0d30af8e2be6ea4578862d604b\PaintDotNet.Framework.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\03da982fa40998999c95968f2e1fa285\PaintDotNet.Data.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Effects\47424e3c2c64cc64d51216032d2e50cc\PaintDotNet.Effects.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet\2a21b6fad8101a4a46ee2c97106d6d16\PaintDotNet.ni.exe, version=4.5.5454.39504 C:\Windows\system32\dwrite.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\system32\OLEAUT32.dll, version=6.1.7601.18640 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\system32\shell32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\nlssorting.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\system32\version.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.0.30319.18444 built by: FX451RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\03047081b78302c8abf4c7d0cc4cb82a\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.5.5454.39504 C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll, version=4.5.5454.39504 C:\Windows\system32\MSVCR120.dll, version=12.00.21005.1 built by: REL C:\Windows\system32\VCOMP120.DLL, version=12.00.21005.1 built by: REL C:\Windows\system32\MSVCP120.dll, version=12.00.21005.1 built by: REL C:\Windows\system32\PROPSYS.dll, version=7.00.7600.16385 (win7_rtm.090713-1255) C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18455_none_2b283fd671e9bf4d\gdiplus.dll, version=6.1.7601.18455 (win7sp1_gdr.140425-1537) C:\Windows\system32\dxgi.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\dwmapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\WINTRUST.dll, version=6.1.7601.18526 (win7sp1_gdr.140706-1506) C:\Windows\system32\CRYPT32.dll, version=6.1.7601.18526 (win7sp1_gdr.140706-1506) C:\Windows\system32\MSASN1.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\profapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\CLBCatQ.DLL, version=2001.12.8530.16385 (win7_rtm.090713-1255) C:\Windows\System32\UIAnimation.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\comctl32.dll, version=6.10 (win7_rtm.090713-1255) C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18201_none_a4d3b9377117c3df\comctl32.dll, version=6.10 (win7_rtm.090713-1255) C:\Windows\system32\WindowsCodecs.dll, version=6.2.9200.17170 (win8_gdr.141105-1510) C:\Windows\system32\wtsapi32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\WINSTA.dll, version=6.1.7601.18540 (win7sp1_gdr.140716-1508) C:\Windows\system32\d2d1.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\d3d11.dll, version=6.2.9200.16570 (win8_gdr.130327-1526) C:\Windows\system32\D3D10Warp.dll, version=6.2.9200.17033 (win8_gdr.140615-1509) C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Xaml\1cf956491787a78c07789c9c8ffb7115\System.Xaml.ni.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Xml\25e7c1b5f922b2b44c27857e1b466651\System.Xml.ni.dll, version=4.0.30319.34234 built by: FX452RTMGDR C:\Windows\system32\RpcRtRemote.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\aticfx64.dll, version=8.17.10.1333 C:\Windows\system32\atiuxp64.dll, version=8.14.01.6413 C:\Windows\system32\atidxx64.dll, version=8.17.10.0581 C:\Windows\system32\winmm.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\explorerframe.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\DUser.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\DUI70.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Program Files\Paint.NET\Effects\AA's_Assistant.dll, version=1.1.4329.33034 C:\Program Files\Paint.NET\Effects\AdvancedRotate.dll, version=1.0.3663.28009 C:\Program Files\Paint.NET\Effects\Alias.dll, version=2.0.3167.14578 C:\Program Files\Paint.NET\Effects\AlignPlugin.dll, version=1.5.1.0 C:\Program Files\Paint.NET\Effects\Alpha2Gray.dll, version=4.0.5284.36690 C:\Program Files\Paint.NET\Effects\AlphaBlur.dll, version=2.0.0.0 C:\Program Files\Paint.NET\Effects\AlphaContrast.dll, version=1.0.3813.18307 C:\Program Files\Paint.NET\Effects\AlphaThreshold.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Alpha_to_0.dll, version=1.0.4452.22746 C:\Program Files\Paint.NET\Effects\Alpha_to_255.dll, version=1.0.4452.22782 C:\Program Files\Paint.NET\Effects\Asmageddon_Alpha works.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Channel multiplier.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Channel_Shift.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Channel_Works_Plus.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Color_Percentage_Plus.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_From P to S Grey.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_From P to S.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_HSV inversion.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Hue Channeling multiply.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Hue Red Psychodelic.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Image coder.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Inverto_pushing.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Inverto_pushing_Caleidoscope.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Inverto_pushing_plus.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Multiplo uniqua.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_PS Mega.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_PS Only.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Pseudo water.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Quadro disorter B.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Quadro disorter.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Render-Border.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Render-Quadro bumperoo.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Render-Quadro inverto.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Render-Quadro sharper.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_RGB tricks.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Strange Bulger B.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Strange Bulger.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Asmageddon_Strange_Bulger Kaleidoscope.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\AutoChrome.dll, version=1.2.0.0 C:\Program Files\Paint.NET\Effects\AutoChromeNoise.dll, version=1.0.3847.37353 C:\Program Files\Paint.NET\Effects\Bars.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\BasicPhotoAdjustments.dll, version=2.1.4020.485 C:\Program Files\Paint.NET\Effects\Basic_Edge_Detector.dll, version=2.0.5346.43075 C:\Program Files\Paint.NET\Effects\BevelObject.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\Bevel_v1.4.0.0.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\Bezncurve.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Bidirectional Blur.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Black and White Converter.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\BlackandAlpha+.dll, version=1.2.4329.272 C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll, version=4.0.4642.26476 C:\Program Files\Paint.NET\Effects\Boutons.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\Burninate.dll, version=4.0.5284.36910 C:\Program Files\Paint.NET\Effects\CalliColour.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\CameraLens.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\CircleText.dll, version=1.4.4415.32488 C:\Program Files\Paint.NET\Effects\ClipWarpNew.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\Cobweb.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\CodeLab.dll, version=2.3.5341.33520 C:\Program Files\Paint.NET\Effects\Color Match.dll, version=4.0.4642.26532 C:\Program Files\Paint.NET\Effects\coloraberation.dll, version=1.0.3859.18981 C:\Program Files\Paint.NET\Effects\ColorBalance.dll, version=4.0.5284.37112 C:\Program Files\Paint.NET\Effects\ColorHarmonies.Effect.dll, version=0.7.0.155 C:\Program Files\Paint.NET\Effects\ColorMixer.dll, version=1.3.0.0 C:\Program Files\Paint.NET\Effects\ColorModulo.dll, version=1.1.3643.38108 C:\Program Files\Paint.NET\Effects\ColorToAlpha.dll, version=2.3.0.0 C:\Program Files\Paint.NET\Effects\ColorTrimming.dll, version=1.0.3167.14623 C:\Program Files\Paint.NET\Effects\ColorZoomBlur.dll, version=1.1.3873.36417 C:\Program Files\Paint.NET\Effects\Compotool.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\Contour.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\CurlyLines.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\CurtisBlack.Common.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\CurtisBlack.Effects.dll, version=11.1.3736.39220 C:\Program Files\Paint.NET\Effects\CurtisBlack.Resources.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Curves+.dll, version=4.0.4642.26561 C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll, version=2.2.5286.39584 C:\Program Files\Paint.NET\Effects\Displacement.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\DistortingMirror.dll, version=1.0.4281.30602 C:\Program Files\Paint.NET\Effects\Donut.dll, version=1.0.4354.32246 C:\Program Files\Paint.NET\Effects\dpyColorBalance.dll, version=1.1.4330.37850 C:\Program Files\Paint.NET\Effects\DragFrom.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\Dream.dll, version=4.1.5307.24374 C:\Program Files\Paint.NET\Effects\Dryad.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\EarthsAndGreys.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll, version=4.0.5120.42730 C:\Program Files\Paint.NET\Effects\EditableText.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\EngraveEmboss.dll, version=2.0.2 C:\Program Files\Paint.NET\Effects\EOEffects.dll, version=1.10.16.12 C:\Program Files\Paint.NET\Effects\ExtendBorder.dll, version=1.3.0.0 C:\Program Files\Paint.NET\Effects\Eyeshine.dll, version=1.0.3700.25905 C:\Program Files\Paint.NET\Effects\FillFromClipboard.dll, version=4.0.5286.32881 C:\Program Files\Paint.NET\Effects\FillFromFile.dll, version=4.0.5286.32800 C:\Program Files\Paint.NET\Effects\Film.dll, version=4.0.4642.26607 C:\Program Files\Paint.NET\Effects\FindEdges.dll, version=1.2.0.0 C:\Program Files\Paint.NET\Effects\Flip.dll, version=4.0.5284.37716 C:\Program Files\Paint.NET\Effects\FloydSteinbergDithering.dll, version=1.0.5321.25313 C:\Program Files\Paint.NET\Effects\Frame.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\FurBlur.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\GaussianBlurPlus.dll, version=3.5.4315.35054 C:\Program Files\Paint.NET\Effects\Gears.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\GenTree.dll, version=0.1.0.0 C:\Program Files\Paint.NET\Effects\Gradient Bars.dll, version=4.0.5152.23084 C:\Program Files\Paint.NET\Effects\Gradient Blocks.dll, version=4.0.4642.26658 C:\Program Files\Paint.NET\Effects\Gradient Blur.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll, version=4.0.4642.26687 C:\Program Files\Paint.NET\Effects\GradientsGalore.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\Grain.dll, version=1.0.3854.25523 C:\Program Files\Paint.NET\Effects\Gravity.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\Gray2Alpha.dll, version=4.0.5284.37903 C:\Program Files\Paint.NET\Effects\Grid Warp.dll, version=4.0.5149.26776 C:\Program Files\Paint.NET\Effects\GridCheckerboard.dll, version=3.0.5297.18928 C:\Program Files\Paint.NET\Effects\GridMaker.dll, version=4.0.0.0 C:\Program Files\Paint.NET\Effects\GrimColorReaper.dll, version=1.2.4299.5808 C:\Program Files\Paint.NET\Effects\Helix.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\HexaGrid.dll, version=1.2.0.0 C:\Program Files\Paint.NET\Effects\Highlight.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\HSVGradients.dll, version=3.0.5299.30308 C:\Program Files\Paint.NET\Effects\HueSatPlus.dll, version=4.1.5333.37244 C:\Program Files\Paint.NET\Effects\IniFile.dll, version=2.0.2 C:\Program Files\Paint.NET\Effects\InputToOutput.dll, version=1.0.3167.14695 C:\Program Files\Paint.NET\Effects\InvertAlpha.dll, version=1.0.3040.33378 C:\Program Files\Paint.NET\Effects\iPhoneTabbarIconMaker.dll, version=1.0.3659.22550 C:\Program Files\Paint.NET\Effects\jchunn.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Jitter.dll, version=4.0.4642.26986 C:\Program Files\Paint.NET\Effects\KaleidoGen.dll, version=1.2.0.0 C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll, version=1.3.0.0 C:\Program Files\Paint.NET\Effects\Landscape.dll, version=4.0.5284.38226 C:\Program Files\Paint.NET\Effects\Lens.dll, version=1.3.0.0 C:\Program Files\Paint.NET\Effects\LensFlare.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\LightRays.dll, version=1.3.0.0 C:\Program Files\Paint.NET\Effects\Liquify.dll, version=4.0.4642.26973 C:\Program Files\Paint.NET\Effects\LocalContrast.dll, version=3.0.0.0 C:\Program Files\Paint.NET\Effects\Magnifier.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\Majority.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\Matrice.dll, version=1.0.3810.11744 C:\Program Files\Paint.NET\Effects\Metallize.dll, version=1.2.4415.32969 C:\Program Files\Paint.NET\Effects\MirrorRotate.dll, version=2.0.2 C:\Program Files\Paint.NET\Effects\MirrorRotateMenu.dll, version=2.0.2 C:\Program Files\Paint.NET\Effects\Moire.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\MotionSharpen.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\MultiThreshold.dll, version=1.1.4330.38982 C:\Program Files\Paint.NET\Effects\Nebulous.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\NewtonFractal.dll, version=0.0.0.0 C:\Program Files\Paint.NET\Effects\NoiseChoice.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\Object2Colour.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\Objectedge.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\ObjectFeather.dll, version=4.0.5284.38364 C:\Program Files\Paint.NET\Effects\Oblique.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Olden.dll, version=1.5.0.0 C:\Program Files\Paint.NET\Effects\OldFeather.dll, version=2.3.4315.37038 C:\Program Files\Paint.NET\Effects\Outline Object.dll, version=4.0.4642.26954 C:\Program Files\Paint.NET\Effects\Outline.dll, version=1.1.3160.31739 C:\Program Files\Paint.NET\Effects\Overblur.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\Overliner.dll, version=1.2.3888.29226 C:\Program Files\Paint.NET\Effects\PageCurl.dll, version=1.4.0.0 C:\Program Files\Paint.NET\Effects\PaletteFromImage.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Panelling.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\PasteAlpha.dll, version=4.0.5284.38515 C:\Program Files\Paint.NET\Effects\Pastel.dll, version=4.0.5284.38621 C:\Program Files\Paint.NET\Effects\PDNPalette.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\PerlinTexture.dll, version=1.1.3857.30918 C:\Program Files\Paint.NET\Effects\Perspective.dll, version=2.1.4415.36116 C:\Program Files\Paint.NET\Effects\PhotoAdjustments.dll, version=4.0.5284.38689 C:\Program Files\Paint.NET\Effects\Pixelate+.dll, version=4.0.4642.26940 C:\Program Files\Paint.NET\Effects\PlugInData.dll, version=1.0.2.10493 C:\Program Files\Paint.NET\Effects\Polar.dll, version=1.1.1.0 C:\Program Files\Paint.NET\Effects\PolariodFrame.dll, version=1.0.3171.27990 C:\Program Files\Paint.NET\Effects\Polygon.dll, version=4.0.5284.38954 C:\Program Files\Paint.NET\Effects\Polygones.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\PrinterPlus.dll, version=1.5.0.0 C:\Program Files\Paint.NET\Effects\Psychocolour.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\pxEexpansion.dll, version=1.0.4437.36287 C:\Program Files\Paint.NET\Effects\Radialcolors.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\RainbowTwist.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\Random Effect.dll, version=4.0.4642.26928 C:\Program Files\Paint.NET\Effects\Random lines.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\Random Maze1.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\Random Maze2.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll, version=4.0.4642.26910 C:\Program Files\Paint.NET\Effects\RecolourChoice.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\RedEyeQuickFix.dll, version=1.1.3161.39688 C:\Program Files\Paint.NET\Effects\RemoveBrightDark.dll, version=1.1.3063.36415 C:\Program Files\Paint.NET\Effects\RemoveDust.dll, version=4.0.5284.39560 C:\Program Files\Paint.NET\Effects\ReverseColors.dll, version=1.0.4121.15722 C:\Program Files\Paint.NET\Effects\ReverseFisheye.dll, version=1.0.5146.21351 C:\Program Files\Paint.NET\Effects\RGB_Remap4.dll, version=1.0.3538.24311 C:\Program Files\Paint.NET\Effects\Rosaces.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\RotateText.dll, version=1.1.4415.32628 C:\Program Files\Paint.NET\Effects\RotateTextSUI.dll, version=1.1.4415.32713 C:\Program Files\Paint.NET\Effects\Rotate_Zoom+.dll, version=1.11.5237.17779 C:\Program Files\Paint.NET\Effects\SBCommon.dll, version=3.0.0.0 C:\Program Files\Paint.NET\Effects\Scintillate.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\Scribble.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\ScriptLab.dll, version=4.0.5146.23014 C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Selection2Clear.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\SelectionObscure.dll, version=1.1.4602.34476 C:\Program Files\Paint.NET\Effects\SelectionTools.dll, version=4.0.5284.39819 C:\Program Files\Paint.NET\Effects\ShadowEffect.dll, version=1.2.0.0 C:\Program Files\Paint.NET\Effects\ShadowHighlight.dll, version=3.0.0.0 C:\Program Files\Paint.NET\Effects\Shape3D.dll, version=1.2.6.0 C:\Program Files\Paint.NET\Effects\Shapes.dll, version=1.4.0.0 C:\Program Files\Paint.NET\Effects\Sharpen+.dll, version=4.0.0.0 C:\Program Files\Paint.NET\Effects\silhouetteplus.dll, version=1.1.3131.17586 C:\Program Files\Paint.NET\Effects\SinWaves.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\Slinky.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\Smooth.dll, version=2.0.2 C:\Program Files\Paint.NET\Effects\Smudge.dll, version=4.0.4642.26844 C:\Program Files\Paint.NET\Effects\Sparkles.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\SpeechBubble.dll, version=2.1.4445.42029 C:\Program Files\Paint.NET\Effects\Spiral.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\SpiralText.dll, version=1.4.4415.32775 C:\Program Files\Paint.NET\Effects\SpiroGraph.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\SpiroShapes.dll, version=2.0.0.0 C:\Program Files\Paint.NET\Effects\Splashes.dll, version=1.1.1.0 C:\Program Files\Paint.NET\Effects\Splatter.dll, version=4.0.4642.26829 C:\Program Files\Paint.NET\Effects\Squirkle.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\SquirkleWarp.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\StarGlow.dll, version=1.0.3839.21249 C:\Program Files\Paint.NET\Effects\Stars.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Stitch.dll, version=4.0.4642.26808 C:\Program Files\Paint.NET\Effects\StringAndPin.dll, version=1.0.1.0 C:\Program Files\Paint.NET\Effects\Textplus.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Tiles.dll, version=1.1.1.0 C:\Program Files\Paint.NET\Effects\Trail.dll, version=4.0.4642.26791 C:\Program Files\Paint.NET\Effects\Transparency.dll, version=4.0.5284.39911 C:\Program Files\Paint.NET\Effects\TreeGen.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\TRsCustomRandomFill.dll, version=1.4.7.0 C:\Program Files\Paint.NET\Effects\TRsFilmStock.dll, version=1.2.0.0 C:\Program Files\Paint.NET\Effects\TubeOblique.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Twist.dll, version=4.0.4642.26767 C:\Program Files\Paint.NET\Effects\TwistZ.dll, version=1.1.2.0 C:\Program Files\Paint.NET\Effects\TwoToneThreshold.dll, version=1.0.0.0 C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, version=3.8.0.0 C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, version=3.8.0.0 C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.dll, version=3.8.0.0 C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, version=3.8.0.0 C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, version=3.8.0.0 C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, version=3.8.0.0 C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, version=3.8.0.0 C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, version=3.8.0.0 C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, version=3.8.0.0 C:\Program Files\Paint.NET\Effects\Vibrato.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\VignettePlus.dll, version=4.0.5284.40018 C:\Program Files\Paint.NET\Effects\Volutes.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\WaterReflection.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\Waves.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\WaveText.dll, version=1.2.4415.32811 C:\Program Files\Paint.NET\Effects\WaveTextSUI.dll, version=1.2.4415.33440 C:\Program Files\Paint.NET\Effects\WetFloor.dll, version=1.1.0.0 C:\Program Files\Paint.NET\Effects\XYCoords.dll, version=1.0.0.0 C:\Program Files\Paint.NET\OptionBasedLibrary v0.7.3.dll, version=0.7.0.229 C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Design\ed419e77e46023dac7729c751db0d722\System.Design.ni.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\assembly\NativeImages_v4.0.30319_64\Microsoft.V9921e851#\224781f2cec3f46da28a52f478472ba0\Microsoft.VisualBasic.ni.dll, version=11.0.50938.18408 built by: FX451RTMGREL C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Configuration\6d01dc933044beec0f2fdefa90f67bd0\System.Configuration.ni.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrcompression.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll, version=11.0.50938.18408 built by: FX451RTMGREL C:\Windows\system32\urlmon.dll, version=11.00.9600.17496 (winblue_r5.141121-1500) C:\Windows\system32\api-ms-win-downlevel-ole32-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\api-ms-win-downlevel-version-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\normaliz.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\iertutil.dll, version=11.00.9600.17496 (winblue_r5.141121-1500) C:\Windows\system32\WININET.dll, version=11.00.9600.16428 (winblue_gdr.131013-1700) C:\Windows\system32\USERENV.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\Secur32.dll, version=6.1.7601.18443 (win7sp1_gdr.140411-1533) C:\Windows\system32\SSPICLI.DLL, version=6.1.7601.18443 (win7sp1_gdr.140411-1533) C:\Windows\system32\api-ms-win-downlevel-advapi32-l2-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\assembly\NativeImages_v4.0.30319_64\WindowsForm0b574481#\2834e3e61ca12bfe75e0db1ab843f0d3\WindowsFormsIntegration.ni.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\assembly\NativeImages_v4.0.30319_64\Accessibility\a875dc03c70e009607b33587df78f638\Accessibility.ni.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Program Files\Paint.NET\FileTypes\IcoCur.dll, version=3.7.0.0 C:\Program Files\Paint.NET\FileTypes\PaintShopProFiletype.dll, version=1.0.2.0 C:\Windows\System32\comdlg32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\MPR.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\System32\drprov.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\System32\ntlanman.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\System32\davclnt.dll, version=6.1.7601.18201 (win7sp1_gdr.130703-2233) C:\Windows\System32\DAVHLPR.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\wkscli.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\cscapi.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\netutils.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\apphelp.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\EhStorShell.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\SETUPAPI.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\CFGMGR32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\DEVOBJ.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\System32\cscui.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\System32\CSCDLL.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\ntshrui.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\srvcli.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\slc.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\msls31.dll, version=3.10.349.0 C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\xmllite.dll, version=1.3.1001.0 C:\Windows\system32\NetworkExplorer.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\System32\StructuredQuery.dll, version=7.00.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\actxprxy.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Program Files\Internet Explorer\ieproxy.dll, version=11.00.9600.17496 (winblue_r5.141121-1500) C:\Windows\system32\api-ms-win-downlevel-shlwapi-l2-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\ntmarta.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\WLDAP32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\thumbcache.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\PSAPI.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\SHDOCVW.dll, version=6.1.7601.18222 (win7sp1_gdr.130725-1535) C:\Windows\system32\ieframe.DLL, version=11.00.9600.17496 (winblue_r5.141121-1500) C:\Windows\system32\api-ms-win-downlevel-shell32-l1-1-0.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\SearchFolder.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\samcli.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\SAMLIB.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\oleacc.dll, version=7.0.0.0 (win7sp1_gdr.110826-1504) C:\Windows\system32\LINKINFO.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\PortableDeviceApi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\EhStorAPI.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\System32\cscobj.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\PhotoMetadataHandler.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\ktmw32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\RichEd20.DLL, version=5.31.23.1230 C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Security\1624d3b0191fc769d07a5c089722e284\System.Security.ni.dll, version=4.0.30319.18408 built by: FX451RTMGREL C:\Windows\system32\SXS.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Program Files\Paint.NET\Effects\CAR.Paint.NET.dll.old, version=1.0.0.0 C:\Windows\system32\rasapi32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\rasman.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\WS2_32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\NSI.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\rtutils.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\mswsock.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\System32\wshtcpip.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\System32\wship6.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\winhttp.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\webio.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\credssp.dll, version=6.1.7601.18606 (win7sp1_gdr.140918-2253) C:\Windows\system32\IPHLPAPI.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\WINNSI.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\dhcpcsvc.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\dhcpcsvc6.DLL, version=6.1.7601.17970 (win7sp1_gdr.121009-0412) C:\Windows\system32\DNSAPI.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\rasadhlp.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\System32\fwpuclnt.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\IconCodecService.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) ------------------------------------------------------------------------------ Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
toe_head2001 Posted January 24, 2015 Author Share Posted January 24, 2015 Hmm, it has happened again, but this time the whole program didn't crash. About half the plugins disappeared from the effects menu, and of the ones remaining some of them were missing their icons. Fun screenshots: Spoiler Here are two examples of the error messages. I hope they help. All of them pretty much say the same thing. Spoiler Alpha_to_0.dll, version 1.0.4452.22746 Name: Alpha_to_0 Type: Alpha_to_0Effect.Alpha_to_0EffectPlugin Version: 1.0.4452.22746 Author: dpy Copyright: Copyright © dpy Website: http://paintnet.web.fc2.com/ System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Type type, String resource) at Alpha_to_0Effect.Alpha_to_0EffectPlugin.get_StaticIcon() at Alpha_to_0Effect.Alpha_to_0EffectPlugin..ctor() --- End of inner exception stack trace --- at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at PaintDotNet.Menus.EffectMenuBase.AddEffectsToMenu() in d:\src\pdn\paintdotnet\src\PaintDotNet\Menus\EffectMenuBase.cs:line 602 ----------------------------------------------- AlphaBlur.dll, version 2.0.0.0 Type: AlphaBlur.AlphaBlur System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Type type, String resource) at AlphaBlur.AlphaBlur.get_StaticImage() at AlphaBlur.AlphaBlur..ctor() --- End of inner exception stack trace --- at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at PaintDotNet.Menus.EffectMenuBase.AddEffectsToMenu() in d:\src\pdn\paintdotnet\src\PaintDotNet\Menus\EffectMenuBase.cs:line 602 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 24, 2015 Share Posted January 24, 2015 Gremlins is as accurate as you're likely to get on this, I'm afraid. Any time I see this particular type of crash or symptom, it defines reason. Maybe you have too many plugins installed ... try removing half of them and see if it still happens. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
