wow64 Posted August 3, 2014 Share Posted August 3, 2014 So I have this photo (Cute I know ) So I am trying to make the small strings of hair transparent without that white wall background being there.So if there is any plugins or ways to get around this please tell me.(Don't worry,I will put AA assistant went I'm done getting rid of the white background.) Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Cc4FuzzyHuggles Posted August 3, 2014 Share Posted August 3, 2014 (edited) I'm not sure if you've seen this already, but it's all I can suggest for the moment. Mini Tut #3 Silhouettes and Quick Image Cut-Out : http://forums.getpaint.net/index.php?/topic/28305-mini-tuts/?p=409110 Edited August 3, 2014 by Cc4FuzzyHuggles Quote *~ Cc4FuzzyHuggles Gallery ~* Link to comment Share on other sites More sharing options...
Pixey Posted August 3, 2014 Share Posted August 3, 2014 (edited) Hi Wow - you can remove the white BG by using the magic wand tool and change the Tolerance in the top toolbar to 16% ahd then press delete. Keep doing this till you get all the white out. Then you can always use the smudge tool to tidy up. After which you can then use the Line Curve tool on a new layer and go over the hair and shirt to get a tidier result. Here are the steps I used: For finer detail on the hair strands, make a new layer and with the color of your background (or just the eraser tool) and a small brush, paint up and down to go over the with the BG color: Edited August 3, 2014 by Pixey Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
