FrostedDimension Posted January 19, 2014 Share Posted January 19, 2014 Whenever I try to use layer properties it doesn't do anything. Quote SLICK SLICK SLICK Link to comment Share on other sites More sharing options...
midora Posted January 19, 2014 Share Posted January 19, 2014 Whenever I try to use layer properties it doesn't do anything. So clicking the item does not open the layer properties dialog? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 19, 2014 Share Posted January 19, 2014 When using layer properties, you typically need 2 layers and you should be adjusting the properties of the top layer. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
FrostedDimension Posted January 19, 2014 Author Share Posted January 19, 2014 So clicking the item does not open the layer properties dialog? It does but when I try an effect it doesn't do anything Quote SLICK SLICK SLICK Link to comment Share on other sites More sharing options...
FrostedDimension Posted January 19, 2014 Author Share Posted January 19, 2014 When using layer properties, you typically need 2 layers and you should be adjusting the properties of the top layer. Ok thanks now it works. Quote SLICK SLICK SLICK Link to comment Share on other sites More sharing options...
