Lyrian Posted December 20, 2012 Share Posted December 20, 2012 (edited) A while ago I had a plugin in which you could select two colours and it would convert the image to be in only those two colours, similar to this. I think it appeared on the adjustments tab rather than the effects tab, and I can't find it to re download, so If anyone knows where I can find it I'd be very grateful. http://imgur.com/vo9G8 Edited December 20, 2012 by Lyrian Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted December 20, 2012 Share Posted December 20, 2012 I think you are looking for either "posterize" or "selective palette" Posterize is in the Adjustments tab Selective palette is in Effects>Color Posterize is built into paint.net Selective palette can be found http://forums.getpaint.net/index.php?showtopic=8043'>in Curtis' Plugin Pack Quote what I do all summer Emote Cursor Pack 'noob gallery No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Lyrian Posted December 20, 2012 Author Share Posted December 20, 2012 (edited) This isn't quite the one I was looking for: for more clarification, you picked two colours in the effect menu before it was applied, and it did this automatically but with nicer quality. It was definitely an effect that got filed in the Adjustments tab. These that you have shwon me should do the same job, so if no-one else knows what I'm talking about they'll do! Edited December 20, 2012 by Lyrian Quote Link to comment Share on other sites More sharing options...
HELEN Posted December 20, 2012 Share Posted December 20, 2012 Try Adjustments-->Cyanotype. Quote Don't spit into the well, you might drink from it later. -----Yiddish ProverbGlossy Galaxy Ball---How to Make FoliageMy Gallery PDN Fans--My DA Link to comment Share on other sites More sharing options...
pdnnoob Posted December 21, 2012 Share Posted December 21, 2012 aha. the image wasn't there earlier...those help a ton I thought you meant only two colors meaning "hex values 003529 and 228593" or something You are looking for the "duotone ink on paper" adjustment in KrisVDM's plugin pack Quote what I do all summer Emote Cursor Pack 'noob gallery No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Lyrian Posted December 22, 2012 Author Share Posted December 22, 2012 Thankoyu, Duotone Ink on Paper is exactly it. Cheers! Quote Link to comment Share on other sites More sharing options...
