opticyclic Posted November 11, 2012 Share Posted November 11, 2012 I have some black and white photos from my wedding and I want to add some colour to them. It looks like it will be too much effort to recolour the whole photo so I might settle for just colouring the waistcoats for a splash effect. I have read lots of tutorials for Paint.NET and for GIMP (http://www.wikihow.com/Recolor-Anything-on-Gimp) Essentially I do the following: Add a new layer Use lasso to select the waistcoat Use bucket fill with the purple colour Select multiply for the layer. This gives me the result I am looking for, but only in the region that I have selected. Not surprising really, but something that I can't get right and that seems to be skipped over in all the tutorials is: how do I select the area correctly? Unless I go down to a really high zoom and spend ages with the selection, I end up either not selecting everything or I end up with leakage into other parts of the clothes. This tutorial (http://www.recolored.com/tutorial_quickstart.php) for a paid for product seems to let you just roughly choose your selection then it uses some algorithm for edge detection to make the correct selection. Is there anything in Paint.Net to help me choose the selection like this? I have tried the magic wand, but the since the picture is greyscale, it chooses random selections all over the image instead of just the waistcoat. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 11, 2012 Share Posted November 11, 2012 Hi opticyclic, welcome to the forum. You have most of the steps in place, so you're almost there! The trick is to make a composite selection with the Magic Wand tool. Lower your tolerance (to avoid leakage outside the waistcoat area) then hold down the Ctrl key to chain multiple selections together. Each time you click, another sliver of selection will be added. The Ctrl key toggles the Selection Mode to Add You might also need to toggle the Flood Mode to Contiguous (i.e. pixels must be neighbors) as opposed to the Global mode (any pixel in the layer satisfying Tolerance will be included in the Selection). Find this option in the Tool Bar when the Magic Wand is active. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
