mszlazak Posted August 27, 2010 Share Posted August 27, 2010 I've used a "threshold" tool that comes with one of the plug-ins to blacken out backgrounds that I wanted removed from a photo. The problem is that this doesn't work well or easily in general and I would appreciate help with techniques to deal with photos like the one attached. In this photo, I want only the family/people without the back ground of the house (etc). Thank you. Quote Link to comment Share on other sites More sharing options...
Zipit Posted August 27, 2010 Share Posted August 27, 2010 (edited) I've used a "threshold" tool that comes with one of the plug-ins to blacken out backgrounds that I wanted removed from a photo. The problem is that this doesn't work well or easily in general and I would appreciate help with techniques to deal with photos like the one attached. In this photo, I want only the family/people without the back ground of the house (etc). Thank you. It would be great to have a tool that removes backgrounds but as far as I know that does not exist. Using an eraser tool to make a halo then zooming in on your photo (400%+) to erase or paint pixels helps. Moving back and forth between 100% and 400%+ and making small adjustments helps. Photographers often use a blue or green screen (or just plain background) to make it easier for removing backgrounds. The magic wand tool helps if you have stark contrast but in a photo like your example, I think you'll have some work to do. Here is an example of using: zoom in/out, eraser (adjusting size), colour picker, paint brush (adjusting size) Uploaded with ImageShack.us Edited August 27, 2010 by Zipit Quote Link to comment Share on other sites More sharing options...
Sarkut Posted August 27, 2010 Share Posted August 27, 2010 There's usually more than one way of doing things. I'd probably build a mask on a new (transparent) layer, blocking out with black whatever I wanted to keep of the family group. Maybe starting with a filled Lasso Selection and refining it from that. Use the mask with the Alpha Mask Import plugin. After the effect is applied to the family image,examining the result will show whether the mask needs adjustments. Adjust and repeat until it looks right. It will be difficult to retain the natural appearance of the hair at the edges. You can fake the hair strands at the edges using Smudge with a rough brush. ===================================================== Whatever method you feel most comfortable with is the way to go. Quote Link to comment Share on other sites More sharing options...
LFC4EVER Posted August 27, 2010 Share Posted August 27, 2010 This tutorial may help: http://www.isimonbrown.co.uk/cutting-out-images/ combine it with alpha masking and you should get yourself a clean cut out, except the hair, which is always a problem. Quote ☆★☆★Merry Christmas★☆★☆ .::.My Gallery.::.Make Gold Text!.::. Link to comment Share on other sites More sharing options...
mszlazak Posted August 28, 2010 Author Share Posted August 28, 2010 This tutorial may help: http://www.isimonbro...ing-out-images/ combine it with alpha masking and you should get yourself a clean cut out, except the hair, which is always a problem. Thanks to everyone. This link and the other comments helped a lot. I like the method of using the pencil or brush on a transparent over layer. Quote Link to comment Share on other sites More sharing options...
mszlazak Posted August 28, 2010 Author Share Posted August 28, 2010 It would be great to have a tool that removes backgrounds but as far as I know that does not exist. Using an eraser tool to make a halo then zooming in on your photo (400%+) to erase or paint pixels helps. Moving back and forth between 100% and 400%+ and making small adjustments helps. Photographers often use a blue or green screen (or just plain background) to make it easier for removing backgrounds. The magic wand tool helps if you have stark contrast but in a photo like your example, I think you'll have some work to do. Here is an example of using: zoom in/out, eraser (adjusting size), colour picker, paint brush (adjusting size) Uploaded with ImageShack.us Zipit, is there a way to smooth/curve out the husbands left elbow? The picture was cropped there leaving a straight line at that location. Quote Link to comment Share on other sites More sharing options...
topfree Posted August 31, 2010 Share Posted August 31, 2010 For the elbow you can use the smudge plug-in. I attempted an example but I don't know what the guy's elbow looks like so I just kinda guessed. Quote Bring your art to life with a a 2d physics program called "phun" . For example videos visit My Phun Videos Link to comment Share on other sites More sharing options...
