prittstick Posted August 23, 2010 Share Posted August 23, 2010 Hi, As a newbie could someone help with this please? I,m trying to place three different pictures of the same object side by side to form just one picture. I also need to see a scale on the final picture, so its important I get the size correct of all three pics. Can some one help please? I,m sure its easy but i,m having trouble. I also need to take out any background from the pictures to leave just the object. What I,m trying to do is post on the Portable Antiquities Scheme web site, which is a place to record metal detecting finds and objects..Hence the need for one picture showing front, back ,and side of the same object... Thanks in advance p Link to comment Share on other sites More sharing options...
himself22 Posted August 23, 2010 Share Posted August 23, 2010 Please change the topic title. 6) Thread titles must be descriptive and specific -- NOT generic. You need to use descriptive thread titles. "The truth is just an excuse for having a lack of imagination." Photobucket sucks! Link to comment Share on other sites More sharing options...
az2000 Posted August 23, 2010 Share Posted August 23, 2010 I,m trying to place three different pictures of the same object side by side to form just one picture. Look at the "layers" feature. You can create 3 layers in addition to the first layer which should be considered the background layer. Put one image in each layer. You can move each image independently by changing which layer you're working with in the layer's window. (You can hide or show layers with that window too. Useful when laying things out.). I also need to see a scale on the final picture, so its important I get the size correct of all three pics. You should post an example of the scale. But, that would just go in another layer, and positioned independently just like the 3 images. I also need to take out any background from the pictures to leave just the object. That was discussed recently here: Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 23, 2010 Share Posted August 23, 2010 Thread closed. "Help!" as a thread title is completely unhelpful. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
