indusarts Posted February 27, 2010 Share Posted February 27, 2010 I have saved a logo I made as a bitmap to export to a CAD program. It works OK except the logo has a box or border around it. Is there a way I can save - in BITMAP FORM - the image without the border? It has to be bitmap, because that is the only image format I can import into AutoCad. Thanks Mark Springer industrial arts Quote Link to comment Share on other sites More sharing options...
pyrochild Posted February 27, 2010 Share Posted February 27, 2010 Crop the border out. PLEASE DON'T SHOUT Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
Sarkut Posted February 27, 2010 Share Posted February 27, 2010 indusarts, Can you post a link to the image so we can have a look at it? Quote Link to comment Share on other sites More sharing options...
pyrochild Posted February 27, 2010 Share Posted February 27, 2010 Oh, if by border you mean background, BMP in Paint.NET doesn't support the alpha (transparency) channel. For that, you'll want this plugin. Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
Possum Roadkill Posted February 27, 2010 Share Posted February 27, 2010 Hi Mark, If you are trying to get just the logo without any kind of border around it, I'm afraid that you will not be able to when you import it into AutoCAD. Have you considered importing it into AutoCAD and then redrawing it as a .dwg? I'm a 20 year vet using AutoCAD and I understand what you are trying to do. If the logo is not too complex, you should be able to recreate it as a drawing file and then make it a block that you can insert into your plot page layouts. Keep in mind that if you are plotting on a white media, a white background on your logo won't show up anyway. What version of AutoCAD are you using? Quote My Gallery SAC, WOTW and Photo Manip Competition Host To visit the Comps click HERE Link to comment Share on other sites More sharing options...
