Illnab1024 Posted September 9, 2006 Share Posted September 9, 2006 Using color palette More mode in Colors window Okay. type a number into the Value slider. Add it to the color palette. Type a different color into the value slider. You should see that the same color as before is added, not the one you have typed in. Is this because the color is not being refreshed when it sees a different value in the textbox? EDIT: By color, I mean the one in the box you click to add a color to the palette. Quote ~~ Link to comment Share on other sites More sharing options...
BoltBait Posted September 10, 2006 Share Posted September 10, 2006 I noticed this as well. Also, if you use the up arrows/down arrows the color in the "add color to palet" does not changed either. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 10, 2006 Share Posted September 10, 2006 Hmm good find. Looks like the 'add color' button's color just isn't updating at the right time. I've filed a bug. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 12, 2006 Share Posted September 12, 2006 This should be fixed for the next build. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
