Posted
Hi all,
I'm probably being thick, but please can anyone help me create a line that fades out to points at the end? I'm pretty good on PdN, I think it's ace, and I can usually find reasonably easy workarounds for any problem I have, but this has got me stumped.
I'm working on a black background with a horizontal neon blue line. For 1-2 px lines I usually motion blur along the line, but this line has to be fairly thick, 6-8 px. When I try this it gives me, even with rounded ends, just ill-defined blurs. Gaussian doesn't seem to work either.
A search reveals the wonderful Simon Brown showing a sharp end as an option for the line tool, but I don't have that. A painful workaround would be to start with a 7px line, then a centred, longer, 5px, then a 3 etc., and then motion blur, but I'm hoping there may be an easier way.
If you can help, that would be lovely, and you'll be on my virtual Christmas card list. :)
Thanks.
Posted
See if this does what you want.
On a new layer make a long, fairly thin, elliptical selection,
fill it with blue, deselect.
Gaussian blur quite a bit, make a rectangular selection
around it and squash it using the Move Selected Pixels
tool on a middle node of a long side.
Posted
That sort-of works, if I scale the canvas up, create a really thick line, and then squash it as you suggested, then stretch the ends and then scale down. I wanted quite long points at the ends, but I think I'll just need to mess with the line dimensions.
Cheers! A Christmas card will be winging its way to you!
Posted
Sorry, your technique is spot on for me. I was using the circle tool to create an elipse, because I hate aliasing caused by the selection tools, but then I realised I'd be blurring.
Doh!
Thanks again.
