Text entry "®" problem
So, I'm using Paint.net to enter some text on a bitmap and found a very minor issue.
I was trying to input the ® character by using the keyboard sequence Alt-0174. When I pressed the 4, the cursor moved left one letter. So when I let go of the Alt key I had "Inte®l" instead of "Intel®".
When the Number Lock is "on", I don't see the problem.
Ok, I've fixed this. You'll see this working normally in the 2.72 release by this weekend.
Illnab1024, I have no idea what your post means or is referring to.
