Stepminer Posted June 24 Share Posted June 24 (edited) having a big problem,so im working on a mod for a game but to replace the textures i need to resize the files,the problem is that every single time i try it it becomes blurry,i tried using every single resize method but never worked. Edited June 24 by Pixey Title too long. Quote Link to comment Share on other sites More sharing options...
Pixey Posted June 24 Share Posted June 24 @Stepminer welcome to the forum I edited your title, as it was too long. Yes, when you resize an image, it can become blurry. You will need a starting image with a higher resolution. Try using AA's Assistant on your image - it may make it sharper. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Disk4mat Posted June 24 Share Posted June 24 I see a few challenges with this. The color depth, the edges of the image are an issue and the ultimate resulting size. You can make it better, by reducing the empty canvas (cropping empty space) and then resizing to 10 pixels. Since the image is on an angle there will be wasted pixels that will get lost in resizing. For this mod is your need to resize the files defined by resolution? Or file size on disk? I think we need some more information on the goal. Quote Link to comment Share on other sites More sharing options...
