Granadine Aeterna Posted November 27, 2022 Share Posted November 27, 2022 MacIntosh is a better than Windows when it comes to Design/Photo Editing. So I really don't see why there WOULDN'T be a release for Mac. Which raises the question: Will there ever be a release for Mac? Quote Link to comment Share on other sites More sharing options...
Solution TrevorOutlaw Posted November 27, 2022 Solution Share Posted November 27, 2022 (edited) Had you read the FAQ: (1) Will it ever be ported to Mac OS, GNU/Linux, or any other operating system? (2) What about Mono support? Wouldn't that be really easy? We will not be doing any work to directly support Mac OS, Linux, Mono, or any other platform. We are doing this in order to focus on the best quality and support for the platform that we develop on: Windows with .NET. Also, we simply do not have the resources or expertise to do any of this work. edit: also this tutorial points to using virtual machine to run paint.net within Mac. Edited November 27, 2022 by TrevorOutlaw 1 Quote Paint.NET Gallery | Remove Foreground Object Tutorial | Dispersion Effect Tutorial Link to comment Share on other sites More sharing options...
Granadine Aeterna Posted November 27, 2022 Author Share Posted November 27, 2022 Thank you, and sorry, i didnt read the FAQ, it didn't even come to mind 😅 1 Quote Link to comment Share on other sites More sharing options...
TrevorOutlaw Posted November 27, 2022 Share Posted November 27, 2022 Just now, Granadine Aeterna said: Thank you, and sorry, i didnt read the FAQ, it didn't even come to mind 😅 No worries. My advice, if you are serious about sticking with Mac, is to make sure you have a very generous RAM. My last go-around with Parallel caused systematic slow down of the Mac to the point everything came to a crawl, and I finally had to return to PC. I think Parallel is better in that it will handle the licensing, a big issue for Windows, and ease of installation of programs. Quote Paint.NET Gallery | Remove Foreground Object Tutorial | Dispersion Effect Tutorial Link to comment Share on other sites More sharing options...
