Oh my gosh... rotation is hard! Need rotation help please.
Go to solution Solved by AndrewDavid,
i have this image:
I want to take the face of this block and rotate it so it is oriented to fit on the lower and right faces of this block.
I got the lower face rotated "ok", but dad-gum if I can't get any sort of rotation for that right face.
I wish I could just control the rotation along the specific X, Y, and Z axes one at a time...
Thank you PDN geniuses!!
  • Solution
If you have the original texture, you may want to use Shape3D and start from the beginning. It would be a bit of work, but you can rotate it to your hearts desire.
If you need to create the texture/pattern, there is a tut that can help you.
Although your image appears to be on a transparent layer, it is not.
Thank you for the reply!
I do indeed have the original texture: I made it myself.
I also have the Shape3D plugin, but when i apply the plugin to this image, it only applies the image to the front face, and no other faces.
Indeed, I used both of the tutorials in that post that you linked to make the diamond plate image I posted.
I'm not sure I understand what you mean here. If the image I created is on its own layer, and there's no other pixels on the layer, would that not mean that the rest of the layer is transparent?
EDIT:
Oh, yeah. Shape3D DOES work, I just had to select the correct texture map :)
Edited by Mervil
