zona Posted January 4, 2022 Share Posted January 4, 2022 So I'm currently trying to make an Icon pack with different neon colored circles however, I want to make sure each icon I make have the same sized circle as it will look odd if not. I know the size of the current circle is 5.98x5.98 however it'd be much easier if there were a way to just import the size width and length wise. I am unsure how to do this as I'm not sure what size the circle is when I've edited a new icon. Is anyone able to assist me? Not sure if there's a plugin or so for it but any help will be useful! Quote Link to comment Share on other sites More sharing options...
Tactilis Posted January 5, 2022 Share Posted January 5, 2022 That looks like a massive image for an icon. You should view sizes in pixels: What size (in pixels) are your icons supposed to be? Quote Link to comment Share on other sites More sharing options...
ardneh Posted January 5, 2022 Share Posted January 5, 2022 Start with a circle that is the size that you want. Apply it as a mask, using the Paste Alpha plugin to layers filled with each desired color. 1 Quote Link to comment Share on other sites More sharing options...
NSD Posted January 5, 2022 Share Posted January 5, 2022 You can use the Shapes plugin from the Render submenu. But first you need to choose the following: 1. Primary color 2. Paintbrush width 3. Selection: Fixed Size (with values as you need) • Make a selection on the canvas • Run the mentioned plugin: Shape = Circle Number of steps = 1 External margin (with values as you need depending on the thickness of the brush) Quote Link to comment Share on other sites More sharing options...
