Paint.Net is unbound from right click -> Edit
Go to solution Solved by Zagna,
Hello.
How Paint net worked for me for years (Windows 10) was the following:
If I double click on an image file, it opens in the Windows Photo Viewer.
When I do "right click -> Edit" , it opens in Paint.net.
This is how I love and need it.
But in the last few days since I last used the program, both Paint.net and Win10 have updated.
And now when I do "right click -> Edit", it opens images with Paint 3D. (Ew!)
I would like to restore it to it's previous function.
PS:
The solution is NOT to do "open with ..." -> "Always use this app".
That would change the double click behavior, but not the "right click -> Edit"
Or do it via registry:
  • Run regedit.exe from the ‘Run’ dialog (Win + R).
  • Go to the following Registry key.
    HKEY_CLASSES_ROOT\SystemFileAssociations\image\shell\edit\command
  • Modify the default (unnamed) parameter. Set it to the full path to the app which you want to use for the Edit menu.
@midora
This kinda worked, but not fully.
I did the edit you said with the following address put in place of regular paint:
Quote
"C:\Program Files\paint.net\paintdotnet.exe"
Now when I right click on an image and do "edit",
it does open Paint.net!
Progress!
But it doesn't open the image that I did the right click on in Paint.net.
It opens a new untitled project, with just a white canvas.
@toe_head2001
Your solution did not work for me.
A re-install didn't solve the problem,
and I do not see the options from your screenshot when I run the installation.
This is all I see when I run the installer:
https://i.imgur.com/2LB6eOQ.jpg
Then you removed and replaced not only the filename but also the parameter after the full path. So add "%1"
The quotes are important because the filepath may contain spaces.
Okay, I think I did what you said.
(Sorry if I don't get it)
and I added what you wrote.
Now the entry in the registry is:
Quote
"C:\Program Files\paint.net\paintdotnet.exe"%1""
It works on image files that have no spaces in their name, but it doesn't work on image files that have do have spaces in their name. Then I get a white canvas and error message.
eg.: right click -> edit works on "picture.jpg"
But when I would try it on "the picture.jpg" I would get the error
"The Image type is not recognized, and cannot be opened.
C:\Users\Admin\Desktop\the"
  • Solution
The command needs to be
"C:\Program Files\paint.net\paintdotnet.exe" "%1"
Space between them and each in their own quotes.
Edited by Zagna
  • Thanks 1
  • Upvote 3
Thank you very much!
This solved the issue.
I can't overstate how grateful I am for your help, patience and expertise.
I will definitely bookmark this, just in case another Windows update will mess things up again in the future.
You're all awesome!
ps:
I wish the installer would still just do this for us.
But I assume you have good reasons for the change, and will/would bring it back as soon as you could. <3
Edited by scg2020
