Reptillian Posted August 26, 2021 Share Posted August 26, 2021 (edited) I am attempting to interpolate between two different HSL value, but I can't seem to figure out why this does not work: double lerp(double a, double b, double t){ return a * (1 - t) + b * t ; } ColorBgra out_hsl(double hue_a,double hue_b,double sat_a,double sat_b,double intensity_a,double intensity_b,double pos){ //new_pos is always in range [0,1). double new_pos = pos - Math.Floor(pos); double H = lerp(hue_a,hue_b,new_pos); double S = lerp(sat_a,sat_b,new_pos); double L = lerp(intensity_a,intensity_b,new_pos); int section = (int)(H/60); double C=(1 - Math.Abs(2*L-1))*S; double X=C*(1-Math.Abs((double)(section%2-1))); double m = L - C/2; double red,green,blue; switch(section){ case 0: red = C; green = X; blue = 0; break; case 1: red = X; green = C; blue = 0; break; case 2: red = 0; green = C; blue = X; break; case 3: red = 0; green = X; blue = C; break; case 4: red = X; green = 0; blue = C; break; default: red = C; green = 0; blue = X; break; } red=(red+m)*255; green=(green+m)*255; blue=(blue+m)*255; return ColorBgra.FromBgraClamped((int)(blue),(int)(green),(int)(red),255); } I have used this source : https://www.rapidtables.com/convert/color/hsl-to-rgb.html It should work because the formula used here are the same. Edited August 26, 2021 by Reptillian Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 26, 2021 Share Posted August 26, 2021 What do you mean by "does not work" ... what outcome are you getting, and what were you expecting Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Reptillian Posted August 27, 2021 Author Share Posted August 27, 2021 (edited) Well, I already solved it. I solved it by isolating the HSL2RGB function into a test code, and figured what's wrong. For anyone stumbling upon this problem: ColorBgra hsl2rgb(double H,double S,double L){ int iH = (int)(H)/60; double C = (1-Math.Abs(2*L-1))*S; double X = C * (1 - Math.Abs((H/60)%2-1)); double m = L - C/2; double tr,tg,tb; switch(iH){ case 0: tr=C; tg=X; tb=0; break; case 1: tr=X; tg=C; tb=0; break; case 2: tr=0; tg=C; tb=X; break; case 3: tr=0; tg=X; tb=C; break; case 4: tr=X; tg=0; tb=C; break; default: tr=C; tg=0; tb=X; break; } tr+=m; tg+=m; tb+=m; tr*=255; tg*=255; tb*=255; tr=Math.Round(tr); tg=Math.Round(tg); tb=Math.Round(tb); return ColorBgra.FromBgraClamped((int)(tb),(int)(tg),(int)(tr),255); } Edited August 27, 2021 by Reptillian Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
