Small Quality-of-Life suggestion about Brush width
Let's suppose you have Brush width 20 and you want to change it. If you open its dropdown list, the current value (20) will be on the topmost position. Then, if you want to change 20 to something larger - 50 for example, you just click it, because this new larger value most likely is visible for you already in the dropdown list (which has 30 entries by the way).
But if you want to change the current value to something lesser, then you have to do an extra step: scroll up by mouse wheel or by dragging scroll bar, because all lesser values aren't visible.
So, my suggestion is: place the current Brush width value in the center of its dropdown list instead of the topmost position.
1 hour ago, HyReZ said:
Greetings,
You could just put the text cursor in the box and type a number into the space such as a brush width of 21.63
It will take just a second or two (literally).
Sure! Also you can use +/- buttons.
I'm just pointing at some "asymmetry".
Btw, in the font size dropdown list the current font size stays where it is, not on the top of the list. Just saying.
