butterfly8000 Posted April 5, 2019 Share Posted April 5, 2019 I have had an issue this has happened several times. I right click on an image and went to print it, it tries to open it in adobe and after that the image will open in paint.net but it will not print. It comes up with errors. I contacted adobe and it says paint.net is the problem not them. I do not believe it is paint.net, I think it is adobe but here I am contacting you letting you know this is happening. Thank you for any insights. P.S. I did uninstall adobe but I am afraid I will have to redo all 100 or so Images I made in paint.net because of this problem. Just so you know they are all JPG and PNG extensions. Thanks for any and all suggestions OS: Windows 8.1 64 bit Adobe DC reader, latest paint.net Jen Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted April 5, 2019 Share Posted April 5, 2019 52 minutes ago, butterfly8000 said: ... it tries to open it in adobe and after that the image will open in paint.net ... Wait... when you click on an image file it opens both programs? Can you check the File Associations in the Windows Control Panel? Control Panel -> All Control Panel Items -> Default Programs -> Set Associations 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
HyReZ Posted April 5, 2019 Share Posted April 5, 2019 @butterfly8000Also check to see if the default printer setting has not been accidentally set to print to an 'Adobe PDF' 1 Quote Link to comment Share on other sites More sharing options...
butterfly8000 Posted April 6, 2019 Author Share Posted April 6, 2019 Will check thanks for that info did not know it would do that. Quote Link to comment Share on other sites More sharing options...
