sonytv Posted September 11, 2017 Share Posted September 11, 2017 i need help please some plugins if anyoen can suggest and i need something for shadeing my cups or art like trees or humans ands objects and items and animals Quote Link to comment Share on other sites More sharing options...
BoltBait Posted September 11, 2017 Share Posted September 11, 2017 "Best" is subjective. The most useful plugin to you totally depends on your artistic style. In order to keep paint.net performant, I would suggest installing only the plugins you actually use on a regular basis. Try installing a few plugins and see if they are useful to you. I recommend starting with the plugin packs that are pinned and starred in this forum: https://forums.getpaint.net/forum/44-plugin-packs/ Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
MJW Posted September 11, 2017 Share Posted September 11, 2017 I suggest looking through the tutorials to find ones that do the type of things you're interested in doing. You can then download the plugins those tutorials use. For certain type of objects, my height map plugins, such as the Texture Shader and Texture Merger, are useful, but generally not so much for things like people and trees. Maybe try the Brush Factory, since that sort of thing pretty much has to be done by hand painting. Quote Link to comment Share on other sites More sharing options...
