italyMB Posted August 28, 2017 Share Posted August 28, 2017 Hello everyone I am experiencing this problem in the latest update: when I select an area in a 12mp image and I move it the scrolling appears laggy, as if the computer couldn't handle the pixel density. Seems strange on a i7. Allready tried running in other Windows compability modes. Anybody had the same issue? Thank you for your help! MB Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted August 28, 2017 Share Posted August 28, 2017 If I remember correctly, the canvas is rendered by the GPU. Can you post your specs, as found in the paint.net Settings window? Settings -> Diagnostics -> Copy to clipboard Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 28, 2017 Share Posted August 28, 2017 Depends a lot on which i7 you're talking about ... not all i7's are made alike Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
NecroVoid Posted August 31, 2017 Share Posted August 31, 2017 yes i have this problem too. cant drag anything anywhere without it lagging and seems like nobody ever has an answer Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 31, 2017 Share Posted August 31, 2017 Without knowing your system specs, especially the exact CPU type, it's hard to give any sort of help or advice. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
italyMB Posted September 22, 2017 Author Share Posted September 22, 2017 (edited) Thank you Rick, hope this helps. Application paint.net 4.0.17 (Final 4.17.6411.1908) Build Date Friday, July 21, 2017 Install type Classic Rendering accelerato via hardware (GPU) True Animazioni True DPI 120.00 (1.25x scale) Lingua it-IT OS Windows 10 x64 (10.0.15063.0) .NET Runtime 4.0.30319.42000 Physical Memory 8,072 MB CPU Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz Speed ~2904 MHz Cores / Threads 2 / 4 Features DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, XSAVE Video Card Intel(R) HD Graphics 620 Dedicated Video RAM 128 MB Dedicated System RAM 0 MB Shared System RAM 4,036 MB Vendor ID 0x8086 Device ID 0x5916 Subsystem ID 0x14901043 Revision 2 LUID 0x00008745 Flags None Outputs 1 Video Card NVIDIA GeForce 930MX Dedicated Video RAM 2,019 MB Dedicated System RAM 0 MB Shared System RAM 4,036 MB Vendor ID 0x10DE Device ID 0x134E Subsystem ID 0x14901043 Revision 162 LUID 0x000094EB Flags None Outputs 0 Video Card Microsoft Basic Render Driver Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 4,036 MB Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x000094D3 Flags Software Outputs 0 Edited September 22, 2017 by italyMB Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 22, 2017 Share Posted September 22, 2017 Okay thanks. This might be related (no fix though yet): https://forums.getpaint.net/topic/111747-paintnet-slows-down-quickly-and-eventually-freezes/ I have a task filed to investigate performance on systems with dual core CPUs. Something may have regressed here. (paint.net's performance is mostly affected by clock speed and core count ... i3 vs i5 vs i7 is mostly about cache size on the laptop/mobile side of things) Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
