anderpainter Posted November 22, 2016 Share Posted November 22, 2016 (edited) Hi, P.N seems unusually slow—at least on my system—at saving larger images. For example, I'm currently working with an image that's about 8K x 8K. When I saved it as PNG, then again as GIF, P.N took nearly a minute to create each preview, then nearly another minute to save the image itself. At these times, I noticed P.N was using only about 25% of my system's quad-core CPU. Could this mean that P.N can't utilize more than one core at a time? If so, can that be improved? Also, could it be easier to skip previews when saving images? When I click OK in the preview window, P.N. seems to cancel the preview (a "Save Configuration" dialog box appears that says "Canceling..."), but this doesn't seem to shorten the time I must wait till the "Save As..." window appears. (And BTW, when you Edit a post here, the button to save your changes is cryptically labeled Edit Topic—which you're already doing. Save Changes seems more intuitive.) Edited November 22, 2016 by anderpainter Quote Link to comment Share on other sites More sharing options...
dipstick Posted November 23, 2016 Share Posted November 23, 2016 I believe it's just a RAM issue not CPU. Image editing uses very little cpu (with exception of certain plugins) and is more RAM intensive, especially with large images. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 24, 2016 Share Posted November 24, 2016 No, it's probably a CPU thing. GIFs and PNGs take a lot of CPU for saving, especially if you're doing 8K x 8K. They can't be parallelized, and they're handled by a Windows OS component (Windows Imaging Component, aka WIC). If you save as PDN, it will utilize all your cores. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
dipstick Posted November 25, 2016 Share Posted November 25, 2016 Yes, you're right. Saving a large test image to .pdn utilized all 8 threads. Saving to jpg used only one thread. The save preview used 4 threads however. Quote Link to comment Share on other sites More sharing options...
