giannic13 Posted May 16, 2016 Share Posted May 16, 2016 There are those ? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted May 16, 2016 Share Posted May 16, 2016 Can you show us an example image that you are trying to emulate? Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Eli Posted May 16, 2016 Share Posted May 16, 2016 I have not seen an effect that creates stitches but you can improvise with TR's Paste Frame effect. If you want leather texture this is a tutorial to make texture that looks like leather. This is another way using the tutorial but using MJW's Texture Shader effect. Quote Link to comment Share on other sites More sharing options...
Eli Posted May 16, 2016 Share Posted May 16, 2016 This is an example of what you can do with the effects mentioned above : 3 Quote Link to comment Share on other sites More sharing options...
Cc4FuzzyHuggles Posted May 16, 2016 Share Posted May 16, 2016 Hello. I'm not sure if this is the type of stitch you are wanting, but it is a fun plugin. http://forums.getpaint.net/index.php?/topic/5936-stitch/ 1 Quote *~ Cc4FuzzyHuggles Gallery ~* Link to comment Share on other sites More sharing options...
