Talon Posted July 7, 2008 Share Posted July 7, 2008 I cant figure out how to make glass buttons, i have tried to read tutorials and it didn't help, if anyone could help that would be awesome thanks! Quote Link to comment Share on other sites More sharing options...
Aussi3ies Posted July 7, 2008 Share Posted July 7, 2008 Create your button shape then select it using the magic wand. Then get click the gradient tool and start from the middle and pull up or down. You can also on a new layer create a white rectangle across the top of your button and lower the opacity which gives it that glass effect. There are many tutorials on this. Please use the search. Quote Website: Aussi3ies Website Forum: Aussi3ies Forum Link to comment Share on other sites More sharing options...
Myrddin Posted July 7, 2008 Share Posted July 7, 2008 Glass buttons you say, Talon? A quick search (http://paintdotnet.forumer.com/search.php - found at the top right-hand of the Forum) using the terms 'glass buttons', and narrowing to topics as opposed to posts, would have returned this set of results: [Click] A scan down the list will reveal the perfect tutorial for this, one by the the name of 'Making Glass Buttons'. There's really nothing to the process either. Very simply it's a collection of gradients: one for the background of the button, and a second for the shine. Always try to use Search first, don't rely on people giving you the answer. As you can see, even the phrase you used yourself yielded the best results, so don't think you have to use fancy vocabulary to find things out . Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
RyuinfinityPDN Posted July 7, 2008 Share Posted July 7, 2008 i have tried to read tutorials Huh? You mean you don't understand the instructions? Quote -- Make an Explosion in Space-- Link to comment Share on other sites More sharing options...
ncfan51 Posted July 7, 2008 Share Posted July 7, 2008 Err Myrddin, I think he already searched: ... i have tried to read tutorials and it didn't help... Quote +_+_+_+_+_+_+_+_+_+_+_+ I am a disco dancer. +_+_+_+_+_+_+_+_+_+_+_+ Link to comment Share on other sites More sharing options...
Myrddin Posted July 7, 2008 Share Posted July 7, 2008 In the rush I were, I read the first part and made up the rest. Assumptions got me nowhere fast. I do apologise, Talon. I hope I didn't insult you. I do have my saviour, though: There's really nothing to the process either. Very simply it's a collection of gradients: one for the background of the button, and a second for the shine.See? A hint. A bad one, but one nonetheless... Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
