First post and quick question? RE: Effects On Layers?
There is a drop shadow plugin (I'm too lazy, use the amazing search function!)
For help on using layers, go to the help file (press F1 while using Paint.net)
Does that help?
"Confusion is the welcome mat at the door of creativity." -Michaul Gelb
My Gallery Check it out!
No not really, the drop shadow was mainly an example. What I need to know if I can run Filters/Effects on a layer not just only on the full image.
According to the help file I can blend layers but doesn't look like I can run filters on layers, can this be confirmed?
http://www.getpaint.net/doc/latest/en/L ... Modes.html
Thanks
SD
Does that help?
