Posts
5,029 -
Joined
Last visited
Days Won
155
Posts posted by toe_head2001
Spoked Wheel
Effects -> Render -> Spoked Wheel
Change Log
v1.1 (March 5, 2016)
- Changed: The range for Line Thicknesses now maxes out at 100
v1.0 (Feb 20, 2016)
- Initial release
Download
Spoiler<---- Icon
GPL v3
// Name: Spoked Wheel // Submenu: Render // Author: toe_head2001 // Title: // Version: 1.1 // Desc: Generates a Spoked Wheel // Keywords: // URL: // Help: #region UICode IntSliderControl Amount1 = 5; // [3,20] Spokes DoubleSliderControl Amount2 = 1; // [0.1,1] Wheel Size DoubleSliderControl Amount3 = 0.333; // [0.1,0.9] Axle Size IntSliderControl Amount4 = 2; // [1,100] Rim Thickness ListBoxControl Amount5 = 0; // Rim Style|Solid|Dashed|Dotted IntSliderControl Amount6 = 2; // [1,100] Spoke Thickness ListBoxControl Amount7 = 0; // Spoke Style|Solid|Dashed|Dotted IntSliderControl Amount8 = 2; // [1,100] Axle Thickness ListBoxControl Amount9 = 0; // Axle Style|Solid|Dashed|Dotted AngleControl Amount10 = 0; // [-180,180] Rotation ColorWheelControl Amount11 = ColorBgra.FromBgr(0,0,0); // Color #endregion void Render(Surface dst, Surface src, Rectangle rect) { Rectangle selection = EnvironmentParameters.SelectionBounds; float centerX = ((selection.Right - selection.Left) / 2f) + selection.Left; float centerY = ((selection.Bottom - selection.Top) / 2f) + selection.Top; float diameter = (float)Amount2 * Math.Min(selection.Width - 4, selection.Height - 4) - Amount4; float radius = diameter / 2f; float offsetX = centerX - radius; float offsetY = centerY - radius; float axleDiameter = (float)Amount3 * diameter; float axleOffsetX = centerX - axleDiameter / 2f; float axleOffsetY = centerY - axleDiameter / 2f; float start = (float)Amount10; float sweep = 360f / Amount1; dst.CopySurface(src, rect.Location, rect); using (Graphics wheel = new RenderArgs(dst).Graphics) { wheel.SmoothingMode = SmoothingMode.AntiAlias; wheel.Clip = new Region(rect); using (Pen wheelPen = new Pen(Amount11)) { // Draw Rim wheelPen.Width = Amount4; wheelPen.DashStyle = getDashStyle(Amount5); wheel.DrawEllipse(wheelPen, offsetX, offsetY, diameter, diameter); // Draw Spokes wheelPen.Width = Amount6; wheelPen.DashStyle = getDashStyle(Amount7); for (int spoke = 0; spoke < Amount1; spoke++) { float degrees = start + sweep * spoke; double radians = Math.PI / 180 * degrees; float startX = (float)(radius * Amount3 * Math.Sin(radians)); float startY = (float)(radius * Amount3 * Math.Cos(radians)); float endX = (float)(radius * Math.Sin(radians)); float endY = (float)(radius * Math.Cos(radians)); wheel.DrawLine(wheelPen, centerX - startX, centerY - startY, centerX - endX, centerY - endY); } // Draw Axle wheelPen.Width = Amount8; wheelPen.DashStyle = getDashStyle(Amount9); wheel.DrawEllipse(wheelPen, axleOffsetX, axleOffsetY, axleDiameter, axleDiameter); } } } static DashStyle getDashStyle(byte style) { DashStyle dashStyle; switch (style) { case 0: // Solid dashStyle = DashStyle.Solid; break; case 1: // Dashed dashStyle = DashStyle.Dash; break; case 2: // Dotted dashStyle = DashStyle.Dot; break; default: dashStyle = DashStyle.Solid; break; } return dashStyle; }
- 7
Try installing gdi+ and see if that helps. Interestingly enough, I can open your image in my PDN installed in Linux under Wine. I did install gdi+ on that virtual drive.
GDI+ is a component that is built into Windows; it isn't something you'd install (on Windows).
I'm pretty sure the Wine implementation of GDI+ is either using Cairo or simply the X server. So you can't compare apples to oranges.
Version 2.0 posted. It now has gives you complete control over Colors, and also has options for Line Styles.
You even figured out how units are working in NumericUpDowns of OptionBasedEffects!
The IntelliSense in Visual Studio sure helped a lot.
- 2
Midora's OptionBasedEffects are much more flexible, but there's almost no documentation. Midora says they are very similar to the PropertyBased effects of IndirectUI.
I'll post the updated source of my Graph Paper later today.
That will give you an example (not sure how good it really is though, enough to get it to work at least).
- 2
You can't mix WinForm Controls with IndirectUI.
midora has the OptionBasedEffects library. It will create a UI that's similar to InidrectUI, but it's much more flexible and also provides a lot more Controls.
- 1
What does this plugin offer that is not in the built-in Radial Blur effect?
Here's another testing build. I've made some changes to the UI. Please tell me what you think. Designing a good UI can be hard to get right.
---Download Removed---
Hidden Content: Screenshot- 4
Just print a rectangle that has a 3:2 aspect ratio?
Make sure you take DPI into account. http://forums.getpaint.net/index.php?/topic/17049-dpi-and-you-understanding-resolution-for-print-and-web/
Well there you go, that's your problem.
That sounds like bug in an old version. Please confirm that you are using paint.net version 4.0.9.
Your idea would mean there wouldn't be any cut-off edges as the box wouldn't be able to go off of the canvas. For the most part, that actually sounds like a good idea, but then again, there are times where I would want some sides of the box to be purposely cut-off. Perhaps the margins can have the ability to go off of the canvas? (sorry, I don't know what's possible in coding).
Not necessarily. There's no reason why the Margin sliders couldn't have a negative value.
Also, what would give a smaller UI, panning controls, or four margin controls, or would UI size be the same either way? Maybe UI size doesn't matter too much? (I personally am fine with UIs that get a bit long, such as the curly lines UI.)
UI size doesn't matter too much, but I do like to keep them short if I can. I'm more concerned with making UI as intuitive as possible.
- To use a Offset/Pan control, it doesn't make sense to set a margin(s). It makes more sense to simply to set the Width and Height. It would automatically rendered to the exact center of the canvas/selection, and then you could move it around with the Offset/Pan control. I imagine this is what most people would want.
- The other way is to set the four Margins individually to an exact amount. Personally, I like this method, because I'm a nerd that that.
I will most likely go with the Offset/Pan route, but I need to think about the ramifications of each a little more before I decide.
I can offer a suggestion on how to do non-rectangular selections, though it would make the plugin considerably more complex. You could use the distance-transform idea, very similar to the way the Edge Expander works when restricted to the selection. The amount of color would depend on the distance to the edge of the selection, with values less than some distance being uncolored, then a jump to fully colored, which would then fade away. I think panning could be accomplished by adding a distance offset which depends on the XY position. One possible difficulty might be aliasing problems making boundary formed by the transition from uncolored to fully colored look ugly. Perhaps that could be reduced by adding a small transition region, so the coloring would increase rapidly but not instantly.
Considering we are only with one color at a time here, I think there are easier & less complicated ways to do it.
While I'm at it, I'll mention an idea I had, even though it may be a little far from the plugin's original concept. What would be useful is if the plugin could allow embossed shading, so the frame looked like it was lighted by an angled light.
Can you post an image of what that might look like?
Non-rectangular selections would require a rewrite of the plugin. That's not a big deal though; this plugin (or rather the actual algorithm of the plugin) is just a few lines of code. When I figure out a good way of doing non-rectangular selections, I'll release a version 2.0.
As for the Offset, your bullet points do have merit.
However it makes more sense, to me at least, to allow for each of the four margins to be set independently. (plus the code is already written in a way in which this can be done) Otherwise the whole concept of the Margin breaks down.
For example, the Margin is set to 10px, but it's offset by 30px.... so that margin is 40px and that other one is....????
Would that work for you? Independent sliders of each margin?
It could also have a checkbox that allows all four to be linked, like it is now.
When you use a custom Surface as the input for the Gaussian Blur effect, and have the radius set to 0, it will mess with the pixels outside of the selection on the left and right.
Like so:
And of course we all know modifying pixels outside the selection on the Destination canvas will break Undo.
This issue can be seen in plugins like my 'Inset Box Shadow' plugin, and BoltBait's 'Inner Shadow (Selection)'. Just set the Blur to 0 in either of these plugins.
I do not know if this is a new bug, or if it existed in old version of paint.net.
In the mean time, I suppose I can just use an If statement to bypass the Gaussian Blur if the value is 0.
Here's a reduce code example demonstrating the bug. Run it on a selection.
protected override void OnSetRenderInfo(PropertyBasedEffectConfigToken newToken, RenderArgs dstArgs, RenderArgs srcArgs) { if (customSurface == null) customSurface = new Surface(srcArgs.Surface.Size); customSurface.Clear(Color.Purple); base.OnSetRenderInfo(newToken, dstArgs, srcArgs); } void Render(Surface dst, Surface src, Rectangle rect) { // Setup for calling the Gaussian Blur effect GaussianBlurEffect blurEffect = new GaussianBlurEffect(); PropertyCollection blurProps = blurEffect.CreatePropertyCollection(); PropertyBasedEffectConfigToken BlurParameters = new PropertyBasedEffectConfigToken(blurProps); BlurParameters.SetPropertyValue(GaussianBlurEffect.PropertyNames.Radius, 0); blurEffect.SetRenderInfo(BlurParameters, new RenderArgs(dst), new RenderArgs(customSurface)); // Call the Gaussian Blur function blurEffect.Render(new Rectangle[1] {rect},0,1); }
Is it would be neat if the plugin had the ability to move or shift the shadow around, like what the "off set" controls do in the drop shadow plugin or like the pan controls in other plugins.
You can already do this by making a selection before running the plugin. I know it's not the same, but it should work none-the-less.
If you still think you need Offset controls, feel free to convince me.
Version 1.1 posted.
- Added a Opacity slider for @Cc4FuzzyHuggles.
- The maximum value Margin slider is no longer hard coded to 100. (100 was to high for small images, and too low for large images). It is now set dynamically based on canvas/selection size.
Thank you, toe head. This is a nice compliment to MadJik's Frames.
IMO, it fits better under Effects -> Render (like Madjik's).
Would you consider combining the two into one?
If Vignette can be in the Photos menu, why not this? That was my thinking anyways.
Technically speaking, this is not frame. It's literally an inset box shadow (as seen in CSS), with an optional margin.
I'm not interesting in combining the functionality of the two plugins. However, my source code is under a Free Software license, so anyone that wants to use it, has the freedom to do so.
- 3
Does anyone have a working link to the older version of this PSD plugin that works in PDN 3.5.11? The link in the first post is dead.
Thanks.
All the old versions are archived on the project's site.
- 1
Here's the plugin: Inset Box Shadow
- Popular Post
- Popular Post
Inset Box Shadow
Effects -> Render -> Inset Box Shadow
Before:
After(s):
Change Log
v1.3 (Nov 3, 2018)
- Changed: Use the ColorWheel control with a built-in Alpha slider
- Changed: Move the plugin to be in the Render submenu
v1.2 (March 5, 2016)
- New: Added controls to adjust Offsets
v1.1 (Feb 9, 2016)
- New: Added a slider control to adjust Opacity
- Changed: The maximum value for Margin is now set dynamically based on canvas/selection size
v1.0 (Feb 8, 2016)
- Initial release
Download
Source Code
https://github.com/toehead2001/pdn-inset-box-shadow
Icon based on icon from Fugue Icons.
- 11
It's actually in Popular Feature Requests, not the FAQ.
The status of the feature has not changed. Hopefully Rick will feel extra generous soon, and spend his free time to implement this for all of us.
I've thought of a way to completely automate this in code. I'll write the actual code tonight.
- 1
^That should work. I forgot about that plugin.
Set the Softness to 1 in TR's QuickOutliner. Then you'll need to use Gaussian Blur (Clamped), instead of the regular Gaussian Blur (otherwise color bleeding will happen).
That should give the exact same effect that's in your example image.
There's got to be an easy (automated) way to do this.
In CSS, that's called an 'inset box shadow'. I don't think sure such a function exists in .NET.
I'll see if I can hack something together.
I'm not sure this fits your needs, but I came across ILMerge-GUI today. It lets you merge your dependencies into your main .dll file. As its name suggests, it only works with .NET assemblies. It's very easy to use, and It works very well.
- 1
I've never tried it myself, but someone got v3.5 to work.
https://appdb.winehq.org/objectManager.php?sClass=version&iId=19822
Are you using the latest version of Wine? I know the packages provided by many of the distros are still on v1.6.
The only thing I've ever installed under Wine was Age of Empires 2. That works great; even better than it does on Windows.
- 1
in Plugins - Publishing ONLY!
Posted
In the next version, can you please add 'System.Drawing.Drawing2D' to the list of assemblies in the prepended script?
I get tired having to type it out (or paste it) every time I want to use 'SmoothingMode' or 'DashStyle', ect.
I've already patched my local copy, my script won't with other people's CodeLab copy.
