franc Posted April 15, 2008 Share Posted April 15, 2008 Hello, i didn't find this functionality (and neither in the forum): 1. I have selected something and want to move the selection (not the content of that selection) with the arrowkeys (possible in PS). 2. I want to fill the line of the selection with color (e.g. 3px) in PS under menu "Edit / Stroke..." Is it implemented, or will it be? Thank you, franc Quote Link to comment Share on other sites More sharing options...
Ash Posted April 15, 2008 Share Posted April 15, 2008 1. Left click mouse and hold either inside or outside of the selection, the arrow keys will work. 2. After you make the selection, Borders N Shapes plugin. Search harder next time :wink: Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
franc Posted April 15, 2008 Author Share Posted April 15, 2008 Thank you, Ash, now i see the difference to PS: 1. If i move a selection in Paint.NET it will move the content of its layer too. Not so in PS. So i need to make the selection in another (empty) layer, thats it. 2. The Borders N Shapes plugin fills only: Rectangle, Ellipse, Arc and Pie. Not a userdefined selection. Maybe enough sometimes. By the way: is there a Plugin for drawing (maybe userdefined) arrows? The point is: i use Paint.NET for fast editing screenshots (e.g. to use in quick documentations or explanations). formerly i used mspaint, but i Paint.NET seems better. Quote Link to comment Share on other sites More sharing options...
Ash Posted April 15, 2008 Share Posted April 15, 2008 2. The boarder plugin does work with selections, But the selectione needs to be Rectangle and such. 3. There is no need for plugins for drawing arrows. Check: http://www.getpaint.net/doc/latest/en/LineCurve.html on how to select arrows. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
franc Posted April 15, 2008 Author Share Posted April 15, 2008 2. Never mind, not so important. 3. Great! Thats it. 4. Thank you, Ash 5. Regards, franc Quote Link to comment Share on other sites More sharing options...
Rubrica Posted April 15, 2008 Share Posted April 15, 2008 Rectangle, Ellipse, Arc and Pie. I believe you are misunderstanding this plugin: those are the shapes of borders it will make. FOr example, the ellipse setting, with no selection, would make a circle as large as the image. On a selection, it would make a circle the size of the selection. Understand now? Quote Link to comment Share on other sites More sharing options...
franc Posted April 15, 2008 Author Share Posted April 15, 2008 Understand now? Yes, i played with this plugin before, on my search for this PS-feature (Stroke...). But i guess there is no Plugin featuring this PS-feature. Quote Link to comment Share on other sites More sharing options...
