lars-sh Posted December 9, 2007 Share Posted December 9, 2007 Hi all! I found a small issue while playing around a little bit: If I set 3201% for the zoom the box is red and nothing changes. (All okay!) The problem: Now I can't directly close the window! I need to change the zoom down between 1% up to 3200% and it's working again... And now a small question: Why can't I remove a layer by pressing "Del"? PS: Why aren't the translations be sorted in the menu? Quote Best regards,Lars Knickrehm Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 9, 2007 Share Posted December 9, 2007 Deleting a layer is accomplished by Ctrl + Shift + Del (listed in the Layers menu as its shortcut). Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
