MJo Posted September 6, 2007 Share Posted September 6, 2007 Hi, I just downloaded the PAINt and I'm working on the code. A couple of lines there man I have a couple of problems... This listing(but with slightly different erroslisting) comes with a lot of forms when I try to view them at the designer view. Allthough I cai view some of the forms in some projects, but most forms not. -------------------------- One or more errors encountered while loading the designer. The errors are listed below. Some errors can be fixed by rebuilding your project, while others may require code changes. The designer cannot process the code at line 267: this.FormBorderStyle = FormBorderStyle.FixedDialog; The code within the method 'InitializeComponent' is generated by the designer and should not be manually modified. Please remove any changes and try opening the designer again. Hide Edit at Microsoft.VisualStudio.Design.Serialization.CodeDom.XML.CodeDomXmlProcessor.CreateQuoteExpression(XmlElementData xmlElement) at Microsoft.VisualStudio.Design.Serialization.CodeDom.XML.CodeDomXmlProcessor.XmlElementData.get_CodeDomElement() at Microsoft.VisualStudio.Design.Serialization.CodeDom.XML.CodeDomXmlProcessor.EndElement(String prefix, String name, String urn) at Microsoft.VisualStudio.Design.Serialization.CodeDom.XML.CodeDomXmlProcessor.Parse(XmlReader reader) at Microsoft.VisualStudio.Design.Serialization.CodeDom.XML.CodeDomXmlProcessor.ParseXml(String xmlStream, CodeStatementCollection statementCollection, String fileName, String methodName) at Microsoft.VisualStudio.Design.Serialization.CodeDom.VSCodeDomParser.OnMethodPopulateStatements(Object sender, EventArgs e) at System.CodeDom.CodeMemberMethod.get_Statements() at System.ComponentModel.Design.Serialization.TypeCodeDomSerializer.Deserialize(IDesignerSerializationManager manager, CodeTypeDeclaration declaration) at System.ComponentModel.Design.Serialization.CodeDomDesignerLoader.PerformLoad(IDesignerSerializationManager manager) at Microsoft.VisualStudio.Design.Serialization.CodeDom.VSCodeDomDesignerLoader.PerformLoad(IDesignerSerializationManager serializationManager) at System.ComponentModel.Design.Serialization.BasicDesignerLoader.BeginLoad(IDesignerLoaderHost host) ---------- If I quote the line 267 that error vanishes but the serialization problems still occur. As in the other forms too. Thanks MJo Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 6, 2007 Share Posted September 6, 2007 Please remember to post in the correct section of the forum. Moved to General Coding Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Bob Posted September 7, 2007 Share Posted September 7, 2007 AFAIK, due to the localization system, you can't view the forms in designer view. Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
