Text Help
All I want to do is simply warp my text. Can anyone help?
...sure, how do you want to warp it? You could use dents, jitter, octagonal reshape, oblique, twist, tile reflection, bulge, polar inversion, and several other effects.
Is there a particular look you're trying to achieve? Can you link to an example image?
Try the tube oblique plugin, or even the Shap3D plugin. Both will work, its just a matter of figuring them out.
MKT does have an example of how to "arc" text with his plugin on his website(its in japanese...)
Try this:
1. Create a new layer. :AddNewLayer:
2. Type your text slightly above or below the middle of the image.
3. Use MKT's Shape3D plugin (available here) and create a sphere.
Since your layer was transparent except for the text, it should just look like the text is curved around an object.
Hope that helps!
