JLOCaliTCB Posted June 28, 2007 Share Posted June 28, 2007 Hi my name is Jeniffer I am from California.. I just downloaded Paint.net yesterday and I need some help with Combining a face from one picture and putting on someone elses body in a different pic.. I have no idea how to do it... I want it to look like my face in on another persons body.. I hope you know what I mean? Please help me...??? Thanks I am a huge ELvis fan and want to put some pics of Elvis & I together .. But I need to replaces the faces with my faces... TCB & TLC Elvis Rocks!!!! Quote Link to comment Share on other sites More sharing options...
Ash Posted June 28, 2007 Share Posted June 28, 2007 Welcome fellow Californian 1. You will need to find a pic of yourself, facing the same angle as the person's face you wanna replace. 2. Cut out your face. I would use :LassoTool: Lasso Select. 3. Copy your face and paste it to a new layer on the pic you wanna add your face to. 4. Use to move your face into the right spot. Hold right mouse button allows you to rotate your face. 5. Use feather on the layer where you face is. (Set at shrink) 6. Adjust color and other stuff to match your face to the pic. If it looks good now, flatten the layers. Done Hope that helps. Let me know. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
maggyb1 Posted June 16, 2012 Share Posted June 16, 2012 What if I want to take out the whole body out and want to replace it with at least 2 new layers? Quote Link to comment Share on other sites More sharing options...
